Question about Brother XR-65t Mechanical Sewing Machine
We have a brother mechanical one. The bottom thread is too loose and even with a corresponding loose setting of top thread, the stiches are not great. Is there a way to fix it (such as tightening the bottom thread)?
    President:
  • 2,777 Answers
Do you have the booklet any longer for this machine? Is it the XR-65t? It should definitely have a tension setting for the threads. This is a very common problem with all sewing machines, and most all have tension adjustments... something I would have thought you'd have adjusted quite frequently. You definitely can turn a knob somewhere on that machine and tight up that adjustment. That is all that is need.
Thanks
Tim
Posted on Oct 01, 2010
My top stich is tight but my buttom is loose on my brother sewing machine
if the bobbin stitch is loose tighten the top thread tension one number at a time & sew alittle bit & if it's still loose tighten it one more number till you get the correct stitch
Feb 10, 2012 | Brother XL2600 Mechanical Sewing Machine
Suddenly my brother xl-2220 is sewing strangely! The top stich is fine, no tensio issues, but when I look at the bottom stitch it isn't right! The stitch is very loose and looks like the pattern a snake...
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
Apr 21, 2011 | Brother XL-5340 Mechanical Sewing Machine
Lower thread very loose. can=t get even stich top and bottom?? thanks ruth hatch
Unthread and rethread the machine according to the manual. Sounds like you do not have it threaded right, make sure that your needle is inserted right (flat side faces away from you) and that it is not bent, replace it if you aren't sure if it is dull.
Sep 07, 2010 | Brother XL-5130 Mechanical Sewing Machine
How to adjust tension the underside stich is loose and tangled, the top stich is fine
Usually it is your top threading is not right, double check that. Read you manual carefully, even if you think you know how to thread it, do it over again. Good luck
Jul 24, 2010 | White Sewing 935 Mechanical Sewing Machine
Top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
May 01, 2010 | Brother CS6000i Computerized Sewing...
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Tension is gone loopy stiches both top and bottom.
Lift the presser foot when you thread the machine and this should resolve the problem.
When the foot is up, the tension is open and can accept the thread as it should.
When the foot is down, the tension can control the flow of thread according to the setting you have selected.
Feb 19, 2010 | Brother LS-1217 Mechanical Sewing Machine
The top stiches are overlaying and the bottom stitch is loose
Remove the thread from the machine.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the upper tension to 5.
Re-thread the machine.
Oct 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Stiching
It sounds like a thread tension problem. Find the knob for the tension and play around with it (look for instructions in the manual). If that doesnt work it might be the bobbin thread thats too lose in which case I would take it to the store or a repair service and have them show you how to do it.
Jan 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
51 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
