Question about Datamax M-Class M-4208 Printer
We are having trouble while printing bar coded labels, there are streaks going across the label what can stop this from happening?
    Scholar:
    New Friend:
  • 52 Answers
If streaks are perfectly vertical and always present, probably your printhead is scratched and needs to be replaced. Unless the streaks are diagonal and intermittent - then you need adjustment for ribbon wrinkle.
Printheads
Posted on Apr 29, 2014
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
SOURCE: printer not lining up and display doesn't work
You can adjust the display contrast by pressing and holding the MENU key for 10 to 20 seconds to modify the LCD contrast level.
SOURCE: Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Posted on Sep 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Skips Bar Code Labels
It could be software related.  The best way to find out is to restart the computer where the labels are coming from.  Turn your printer off and back on again as well.  Run the program that loads the forms into the printer to print with.
Is the printer on an ethernet connection or is it connected to a computer?
Posted on Oct 21, 2008
SOURCE: PLEASE HELP - Labels are printing in the wrong direction
The ups site ahs a solution to your problem. You need to send a ZT command to the printer to reverse direction
The easiest way to do it is to open the printers properties and go to the advanced tab go to Printing Defaults then select Tools then tools again and a window will popup. Enter ZT and press enter. The Send button should now be enabled. Click on it. DO NOT touch anything else. Close all windows and try printing . If this is not the direction you want , rod and this time enter the ZB then enter. There are only 2 commands ZT and ZB
Good luck
Posted on Dec 03, 2008
S4M Thermal Label Printer: Very thin vertical line in bar code area negating ...
The printhead is starting to go bad. Try cleaning it. If you can't get the line to disappear, you can rearrange the info on your label so that the void does not go across your barcode. Lastly, you can replace the printhead. Hope this helps
May 16, 2010 | Zebra S4M Thermal Label Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
We presently have a Zebra 110XiIII Plus Printer that we use for printing labels containing Text and Bar Codes from an MS Access based application. Our current printer comes with a Roll of paper, and labels...
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
Nov 19, 2009 | Zebra 110Xi III Plus Thermal Printer
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
Problems with printing labels with counter ...
if you are using the free software that came with the printer, it does not print serialized numbers very well past about 160 or so... to stop the pausing uncheck the "Print bar code as a graphic" box and check the "Auto font scaling" box.
Jun 26, 2009 | Zebra S4M Thermal Label Printer
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Datamax M-Class M-4208 Printer Logo
88 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
