Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Audio/video output problem with TV Tuner card
I have been using External TV Tuner card. it was working fine till now. But suddenly it statred showing blank screen on my monitor. No audio/video output is comming out of it. Can you please help what should i do? or what can be problem with it.... I would appreciate your help
  • niprash Aug 15, 2008
    I Dont get video nor audio on my card, installed all the drivers, but no use. please help me asap
  • abdul razzaque
    abdul razzaque May 02, 2014
    no video but audio is
    New Friend:
Tv tuner video input not support
Posted on Dec 25, 2014
Bhaad mein jaa kutte
Posted on Sep 02, 2008
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
Laptop screen blank at start up
If it still doesn't work when you hook it up to an external monitor, assuming you did that properly, then it is your motherboard/video card.
If you have a seperate video card, I would replace that first. If you don't have a seperate video card, then you need a new motherboard.
FIRST - I would try hooking it back up to an external monitor, and making sure you switch it over to use the external as the default. otherwise you wont get picture.
Sorry... good luck.
Sep 10, 2009 | HP Pavilion dv2120us Notebook
Sabrent PCI TV Tuner card won't work on dual monitors
yes it is not possible vew to duel monitoring system it is only single devise
Jul 13, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
Kworld pc to TV - avi does not show on TV screen
This turned out to be due to weirdness in my laptop's onboard graphics card. If I set the external monitor to display the way an external monitor usually does, as a clone of the laptop screen, the videos show up blank. But if I set it as dual-screen (extend my desktop to this monitor) and drag the video app onto the second monitor, it works fine.
Jan 07, 2009 | KWorld PC to TV (0872880887527) Video...
Monitor is blank!!!!
Firstly, the LCD+external setting will switch one or the other or both on.
Secondly, if you go into your display properties (or even the advanced page where your video card additional features are) you can usually select which monitor is "primary".
I suspect that your external display is primary, and the LCD screen is not "enabled" or used as part of the desktop.
The settings are all there, it's just a matter of finding them (depending on what video card is in whatever laptop you have)
This might have happened in the first place if you accidentally hit "Fn" and one of the "F" keys up the top. Fn + F6 on my laptop will switch LCD/external monitors on and off. (for example) There is usually a little blue picture on one of the "F" keys to denote that function.
Sep 09, 2008 | Toshiba Satellite A105 Notebook
No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Nov 14, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
371 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
