Question about Canon PowerShot S2 IS Digital Camera
S2 IS lens cover constantly falls off. Any suggestions/solutions? Roy
    Brigadier General:
  • 11,967 Answers
A small band of tape on the inside rim should provide a snug fit.
Posted on Oct 01, 2010
Testimonial: "Tried that before....was thinking someone out there had tried gluing a strip of moleskin around the inner part of the cover.....Tnx for the reply..Roy"
How to repair lens of canon s3 is
the lens assembly for S3 is pretty complicate. I suggest you get a professional to handle it. It is usually the stuck shutter or failed motor that caused issues on S2 or S3.
There is a guy on eBay that fix both issues for a low price. Fix is for Canon S2, S3, S5 with stuck shutter. here is the link in case you need: http://www.ebay.com/itm/141414188140 and stuck lens: http://www.ebay.com/itm/141334025954
Jan 05, 2014 | Office Equipment & Supplies
Camera has black screen and lens goes in and out quickly error e18 come up before it shuts off
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 11, 2011 | Canon PowerShot S2 IS Digital Camera
Error code E 18 what does this mean?
E18 on older Canon cameras stands for "lens error". Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 01, 2010 | Canon PowerShot S2 IS Digital Camera
I have the Canon power shot s2 is digita. I cant
You might have a mecanical problem at the lens. The only way to surely fix this is at a local electronist or Canon dealer. Trying to repair it yourself can render the camera unusable and unrepairable.
Apr 11, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Nikon AF-SNIKKOR 18-55mm 1.3.5-5.6GII ED and it is ''locked'' at 55. I cannot get it to zoom in. The problem started after the lens was shaken by my camera bag falling to the fall....any...
Sounds like the lens is jammed and the fall did some damage to the lens. You could apply a little more force to the zoom and it may or may not pop back into place. It is work a try since impact/shock is not covered be the warranty; and the cost of repair is almost as much as a new lens.
Nov 15, 2009 | Cameras
The lens cover won't close when powered off
I am loath to suggest hitting it hard (which is what I usually do to mine!) but one solution that tends to work well on the TZ3 is to pop the end of a shop-vac over it when it's turned on. This will **** out any gunk that has got in there that may be blocking it.
Jul 06, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Zoom Lenses for Canon Powershot S2 SI
the s2 IS does not have a changeable lens. i suggest you look for telephoto converters . they attach to your lens and increase the magnification thus boosting your zoom ability. try this link from ebay http://shop.ebay.com/items/_W0QQ_nkwZcanonQ20s2Q20telephotoQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Sep 03, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Jun 17, 2008 | Canon PowerShot S2 IS Digital Camera
Lense cover keeps falling off
The spring must have grown tired, or displaced. If you don?t want to loose it in the meantime, you can glue a string one side to the cover and one side to the camera?s body using small points of super glue. But a more creative solution would be to get to a cannon selling shop and nag them to help you get a new one, or go to a second hand shop and look for a standard cover that?s a good fit for your lense.
Feb 21, 2006 | Canon PowerShot S2 IS Digital Camera
LCD cover on S2
I've had my pre-owned s2 for over a year and have had no problem. Also, I've seen them sold on Ebay.
Sep 04, 2005 | Fuji FinePix S2 Pro Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
