Question about Quorum Ceiling Fan - 138880
On all three settings the fan runs very fast, no slow speed.
If it's a remote fan try completely cutting off the power at the breaker box for a minute or 2 and turn it back on. Mine does that occasionally and that seems to re-set whatever it is in the fan that causes it. Hope it helps.
Posted on Oct 01, 2010
Why does my ceiling fan 897 only spin slowly
If it has chain controls, one changes the direction, Clockwise, Counter clockwise. The other one alters the speed in 4 pulls, from OFF, SLOW SPEED, MEDIUM SPEED, FAST SPEED, and back to OFF. If there are three chains, the third turns the light on an off.
Sep 19, 2015 | Dryers
Why are the fans not coming on in my 1999 deville
99 Deville - have you checked the large fan fuse(s) under and behind the main fuse/relay box ?? (I think this holds for 99 - 2000+ moved the maxi-fuses to the underhood box on the passenger side.)
Also, are your relays on a mount down near the fans ? Some have had trouble with the wiring/sockets there. 2000 or later moved the relays up to the fuse box itself. There are 3 - Fan 1, Fan 2, and a series/parallel (S/P) relay for slow and fast speeds.
Fans run in SLOW at 224 degrees F, FAST at 236 degrees F if there is no air conditioning or DEFROST function set. In the city or heavy traffic the gauge will go to the first tick mark past 12:00 and the fans come on. As the coolant lowers to 213 degrees F the fans turn off and the cycle repeats.
IF you set an air conditioning function, then fans run in SLOW all the time.
If your fans will not run under any conditions, check the large fuses in the underhood fuse/relay box, as well as the small fuses for the fan relays - there are 3 relays: Fan 1, Fan 2, and S/P (series/parallel): the fans are relay set to series operation (voltage drop) for Slow speed, parallel operation (full voltage) for Fast.
Mar 24, 2012 | 1999 Cadillac DeVille
I own a 2005 jeep liberty. the ac, heater fan only works on selector switch setting # 4. nay sugesstions on why fan does not work on settings 1, 2 or 3.
The lower speeds are accomplished by running the power supply through various resistors that drop the voltage which makes the blower turn at different speeds. The lowest setting uses all the resistors to drop the voltage as much as possible to turn the blower as slow as possible. High speed uses no resistors so the blower gets full power and turns as fast as possible.
Since speed 1 and speed 2 use the speed 3 resistor to drop there voltage and speed three is not working as well my guess is the speed three resistor is burnt out in the device referred to as the blower motor resistor or blower motor speed control module. This is located near the blower motor and is held in place with 2 screws. There will be several wires and possibly two connectors plugged into it.
These are really common failures in many vehicles. The parts are usually available at your local auto parts store and they are typically not that expensive.
Hope that helped.
Oct 07, 2010 | 2005 Jeep Liberty
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
Intermittent blower speeds
pull motor ,check for burned wires onfan and bak of fan speed switch,fan could be the problem un hook fan and conect directley to 12 volts and see if varibles exsist,if so replace fan motor/look for a fan resister if all the other things check out
Jul 03, 2009 | 1999 Chevrolet Suburban
Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
May 26, 2009 | Dryers
Fan speed too fast
Is there a light switch control or just straight power to the fan? They do sell "Fan" controll switches just like a regular dimmer, but for a fan. If there is just straight power u would still be able to install a remote that could lessen the speed. Even if it is just pull chains. the remote would have three speeds and if u kept the pull chain on low, maybe the low remote speed could work.
May 22, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Quorum Ceiling Fan - 138880 Logo
269 people viewed this question
Top Quorum Dryers Experts
Are you a Quorum Dryer Expert? Answer questions, earn points and help others
