Question about Frigidaire GLGR331A Gas Dryer
Dryer heats up, but wont dry clothes - Frigidaire GLGR331A Gas Dryer
  • Frigidaire Master
  • 7,482 Answers
Check and clean your lint trap in the dryer.
Check and clean your hose, this could cause a fire if the hose becomes plugged with lint.
Also check your blower in the dryer to make sure the blades are ok and not broken.
Normally these are the cause of clothes not drying if the heating element is working.
This is a FREE answer, Please Rate Me
Posted on Oct 01, 2010
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My Whirpool Gold dryer is heating up to dry the clothes, but the clothes are damp /wet.
Hello
When the dryer wont heat up and dry clothes it means that the thermostat/thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Kevin
Nov 20, 2010 | Dryers
Dryer wont dry, clothes are just as damp as they were at the beginning
Is the dryer heating? If not check heat system for part failure. If it is heating but taking too long to dry check for plugged exhaust. Best way to check exhaust is to disconnect exhaust from back of dryer and dry a load.
Mar 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Frigidaire GLGR331A Gas Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
