Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Single head scald resistant shower fixture. Needs new cartridge. Took screw out plumber cannot get handle off. Called moen it is a 2001 model. But they said cannot help me. Need to cut off and get new fixture. How to get handle off.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
There are several products that can be used to loosen the corrosion holding the handle in place. The Works is one product along with CLR. The easiest fix is to wrap a washcloth soaked in distilled white vinegar around the handle. Let it soak for 20 minutes at a time. It could take a half dozen times or more, but eventually it will work. Rinse the faucet after each application to remove the acid. You may also need to use this process to remove the Moen faucet cartridge.
Posted on Oct 01, 2010
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
Just replaced cartridge in out single handle turn shower handle and now do not get hot enough water. hat could be the problem?
The anti-scald device behind the handle is improperly set. It's the (usually) black ring with 'teeth' on the inside. You obviously misaligned it when during repair. Remove the shower handle, loosen the center stem screw and re-adjust the anti-scald stop device probably ani-clockwise a few notches, then re-tighten the screw and replace the handle.
Oct 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
108 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
