Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I have pluged by seagate free agent usb into my desktop, Windows 7, and it is not appearing. it is visible in the control panel: devices, but it is not accessible. How do i get it to appear and open for use and for backup? thanks you.
  • 734 Answers
If the drive has not yet beenproperly formatted for storage (which would seem to be the case), please follow the next steps.
1. Go to the Start Button and click.
2. In the little search wondow that appears directly above the button type "Computer Management" and a shorcut to that Administrative Tool will appear at the top of a list that pops up.
3. Click the Computer Management shortcut
4.In the new window, look in the left panel and go down to "Disk Management" and click it once.
5.
Posted on Oct 01, 2010
  • Marcus
    Marcus Oct 01, 2010
    5. In the new window that appears, in the center pane, you will see a list of drives and the new external one should be there. Right click on it and a drop down menu will have an option called "Format" Click on that, format.the drive, and it will read and write normally.
    Regards
My seagate free agent 320gb hard drive won't power on
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 19, 2012 | Seagate FreeAgent Pro Desktop - 320GB -...
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have window server 2003 OS and 500 GB free agent desktop USB hard disk is not showing in my computer. So how can i rectify it?
I just finished a Chat exchange with Seagate Tech support. MS Server OS's are not supported for FreeAgent devices.
It appears that whatever drivers exist in the XP install that recognize the USB device connection are not the same in the MS Server environment.
I plan to check the USB device drivers from both systems and see if the XP USB device drivers will work on Server 2003.
Oct 11, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi there, I have a Seagate 250Gb external Free Agent disk that I want to put in to my laptop computer. Any ideas how to get in to the case without breaking it?
I am Satya.
Hope this helps.
You can connect the Seagate 250 Gb external Free Agent disk by using a Usb connector and connect it to the USB port of your Laptop. In this way you can connect the disk to your Laptop computer without breaking it.
Windows will automatically detect the the drive and can be browsed through Windows Explorer as a separate drive.
Hope this helps.
Thank you.
Aug 14, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
82 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
