Question about Cyberhome CH-DVD 300 DVD Player
Reset dvd to
Dvd was switched to progressive manual says to turn off then turn back on and hold stop button for 5 sec. to reset tried but didnt work
  • Ian Walters May 31, 2008
    I just tried the 20-second stop button solution posted on May 29, 2008. Bingo! Works like a charm. I was on the verge of throwing out the CH-300. We too had tried the 5secs. advised in the Manual, with zero result. Thanks a million to the smart and helpful guy who posted the answer. It looks like many of the other outstanding problems on the CH300 can be solved in this way.
  • Anonymous Jun 01, 2008
    ja fiz o procedimento mas continua em prograssive scan
    Nerynew@ibest.com.br
Turn down the power . then turn back on and hold the stop button for 20 sec. this should reset the player
Posted on May 29, 2008
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Pressing stop for more than 5 sec doesn't change 'progressive scan mode'
Please press and hold STOP button for more then 5 seconds to cancel Progressive Scan mode.
Oct 22, 2008 | Philips MDV560VR DVD Player/VCR
CYBERHOME DVD PLAYER WON'T WORK
Dear friend,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Dec 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Not able to turn off Progressive scan feature-sony dvp nc85h
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Jan 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
Oct 20, 2007 | Emerson EWD2202 DVD Player/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Cyberhome CH-DVD 300 DVD Player Logo
191 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
