Question about Eddie Bauer 22-625-BLD
How do i get the straps back in - Eddie Bauer 22-625-BLD
    Sergeant:
  • 168 Answers
Dorel Juvenile Group is the company you contact for any thing dealing with Eddie Bauer
Or, try lookin in this LINK: eddiebauer.djgusa.com Where-to-Buy
I hope help with this info (remember to rate this answer).
Posted on Oct 01, 2010
Where do i locate 5.9 dodge ram 1500 ground straps on 1997
The strap with 3 ends....connect it to the frame. You can strap the alternator to the block.
May 02, 2018 | Dodge Cars & Trucks
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
I cannot get the straps to tighten anymore.
Without the model/make it is hard to say what your exact problem is but normally the manufacture's site has links to the user guide. I do have three areas you may want to look over: First the sholder straps themselves sometimes have loops or labels attachted. Make sure these are not preventing the straps from moving through the slots. Second have you attachted the sholder straps to the splitter, a metal bar attachted to the adjustment strap, if it exists on your model. Have you attachted them correctly. Third see if the splitter is stuck on something in the back.
Mar 20, 2010 | Baby Gear
Hi there. i have purchased the frootmuff for quinny and there is no instructions. im not sure where the straps attach to on the top and there is 2 slits for the soulder straps to go through when i can only...
the first large hole to the bottom of the footmuff is for the **** pad you will then need to remove top section of straps from the pram which is a slide clip then remove the strap covers at this point you can push the straps in the two lower slits at about bottom height then you will need to put the strap covers back on then fit through either the first or second slits in the cosey toes (depending on height of child) attching he straps back to the pram and you are ready to go also most quinny prams have 2 levels which the shoulder straps can be attched i hope this helps x
Nov 23, 2009 | Quinny ZAPP Stroller
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Eddie Bauer 22-625-BLD Logo
121 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
