Question about Konica Minolta Office Equipment & Supplies
We have a Konica Minolta Bizhub C30P laser printer. I am now getting a Service Call message of: Service Call0300 Polygon MOT I have already shut the machine off and on & unplugged it. Still getting message. It will not print at all. Do you have any suggestions?
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
"Service call0300 Polygon Mot"
Polygon motor is the motor located inside the print head where the LASER is at the motor is what moves the LASER beam across the drum when placing the image on the drum. SO you might have a bad print head because the motor and LASER come as one. And no you can not replace the motor separately.
Apr 03, 2015 | Konica Minolta Magicolor 5650EN Color...
Where is the Black Polygon Mirror Motor in the bizhub c203
there are four polygon motors in side the print head which is located below each drums, the polygon motor is what spreads LASER beam across the length of the drum with the image. To replace you replace all four yellow, magenta, cyan and black, black in particular because that is the reference color for the color print heads
Jun 25, 2014 | Konica Minolta Bizhub c203 Copier
Service call 0300 polygon mot
Replace the print head which houses the LASER
Feb 01, 2014 | Konica Minolta PagePro 4650EN - Printer -...
THE COPIER DISPLAYS ERROR C4101
C -4101 Polygon motor error.Change the polygon motor,if you can not reset the malfunction code.
Mar 02, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
Konica Minolta BizHub 222. message "Now
This message usually comes up when someone is accessing the BizHub via the web GUI. Disconnect from the webGUI, and that message should go away.
May 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
