Question about Car Audio & Video
Stereo wiring code for 2005 ford f150 with factory sub
  • sh_tinker Oct 01, 2010
    im installing an after market stereo so i need a wiring diagram for the factory wiring in the truck
  • 503 Answers
  • 1
    Disconnect the negative battery cable from the vehicle's battery. The negative cable is the black cable that connects the negative lead of the car's battery to the frame of the vehicle. Use a Phillips-head screwdriver to loosen the bolt on the cable's clamp. Remove the clamp from the negative lead.
  • 2
    Remove the stereo from the dash. You will need to access the connections at the rear of the unit and feed the wiring kit wires through the same openings as the other wiring.
  • 3
    Mount the subwoofer and amplifier in the trunk of the vehicle. The amplifier can be mounted at other locations (under a seat, in the glove compartment), but the trunk offers the easiest connection to the subwoofer, as well as allowing for proper ventilation.
  • 4
    Connect the ring terminal from the amplifier wiring kit to the positive lead of the battery. Make sure that the fuse is removed from the terminal before connecting the power cable to the ring terminal.
  • 5
    Feed the power cable from the amplifier ring terminal through the firewall, under the vehicle's carpeting, to the trunk. Use a trim panel tool to remove the paneling that secures the carpeting to the floor of the vehicle. The panels can be replaced by hand.
  • 6
    Run the signal cable and turn-on lead from the stereo to the trunk along the opposite side of the vehicle. The power cable will distort the signal if the wires are laid at the same location.
  • 7
    Connect the power cable, the signal cable, and the turn-on lead to the amplifier.
  • 8
    Connect the subwoofer to the amplifier using speaker wire.
  • 9
    Reconnect the negative battery cable. Place the clamp around the negative lead. Tighten the bolt on the clamp until the clamp cannot be moved about the lead by hand.
  • 10
    Place the fuse into the fuse holder on the amplifier ring terminal.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Posted on Oct 01, 2010
    Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
    About 3,970 results (0.89 seconds) Search Results
      Ford Bluetooth® Wiring Harness - Crutchfield
      www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
      Crutchfield Corporation
      Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
      Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
      70-5521 wiring harness for ford with 6 CD premium sub amp ...
      ? 4:30
      https://www.youtube.com/watch?v=0jqNafnki0o
      Aug 9, 2013 - Uploaded by codieraji
      Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
      Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
      www.installer.com/main.php?page=harness
      Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
    Feb 09, 2016 | Ford Cars & Trucks
    Door codes ford pickup f150 2005
    for this concern you will have to go to a dealer a diagnostic tool needs to be connected to retrieve the code. thats if it is factory and or dealer installed.
    Apr 30, 2013 | Ford F-150 Cars & Trucks
    Factory stereo system color diagram for 92 ford f150 5.0l 8cyl. truck
    1992 Ford F150 Truck Car Stereo Wire Diagram
    Car Radio Battery Constant 12v+ Wire: Green/Yellow
    Car Radio Accessory Switched 12v+ Wire: Yellow/Black
    Car Radio Ground Wire: Red or Black
    Car Radio Illumination Wire: Blue/Red
    Left Front Speaker Positive Wire (+): Orange/Green
    Left Front Speaker Negative Wire (-): Black/White
    Right Front Speaker Positive Wire (+): White/Green
    Right Front Speaker Negative Wire (-): Black/White
    Left Rear Speaker Positive Wire (+): Pink/Green
    Left Rear Speaker Negative Wire (-): Pink/Blue
    Right Rear Speaker Positive Wire (+): Pink/Blue
    Right Rear Speaker Negative Wire (-): Green/Orange
    Aug 19, 2011 | Ford F-150 Cars & Trucks
    Car audio wiring color codes.for 1988 ford f150 truck
    Thanks for using FixYa.
    1988 Ford F150 Truck Car Radio Wire Color Codes
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 6?
    Car Audio Front Speakers Location: Doors
    Car Audio Rear Speakers Size: 6? x 9?
    Car Audio Rear Speakers Location: Rear Corners
    google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
    Jan 25, 2011 | Car Audio & Video
    Changing the factory stereo need the color coded wiring diagram
    you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
    Jul 01, 2010 | 2001 Ford Mustang
    I need to know the color codes for the radio rear sub.
    2000 Ford Expedition Car Radio Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: White/Purple
    Car Radio Accessory Switched 12v+ Wire: Black/Pink
    Car Radio Ground Wire: Black/Green
    Car Radio Illumination Wire: Blue/Black
    Car Stereo Amp Trigger Wire: Blue
    Car Audio Front Speakers Size: 6′ x 8′
    Left Front Speaker Positive Wire (+): White/Red
    Left Front Speaker Negative Wire (-): Brown
    Right Front Speaker Positive Wire (+): Green
    Right Front Speaker Negative Wire (-): White/Orange
    Car Audio Rear Speakers Size: 6′ x 8′
    Car Audio Rear Speakers Location: Rear Doors
    Left Rear Speaker Positive Wire (+): Light Blue/Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Purple/White
    Right Rear Speaker Negative Wire (-): Light Blue
    Dec 24, 2009 | 2000 Ford Expedition
    What is the wiring color code for a 2005 ford expedition radio
    use google. i did and i got this
    Car Radio Battery Constant 12v+ Wire: Light Green
    Car Radio Illumination Wire: Light Blue/Red
    Car Stereo Amplifier Location: If equipped, the factory amplifier is located behind the trim panel on the right side of the cargo area.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Orange/Light Green
    Left Front Speaker Negative Wire (-): Light Blue/White
    Right Front Speaker Positive Wire (+): Dark Green/Orange
    Right Front Speaker Negative Wire (-): White/Light Green
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Gray/Light Blue
    Left Rear Speaker Negative Wire (-): Tan/Yellow
    Right Rear Speaker Positive Wire (+): Orange/Red
    Right Rear Speaker Negative Wire (-): Brown/Pink
    May 26, 2009 | 2003 Ford Expedition
    Looking for free radio diagram 91 f150
    here is the wire colors and what they do. it is from the factory electrical guide.
    1991 Ford F150 Truck Car Stereo Wiring Schematic
    Car Stereo Antenna Trigger: N/A
    May 13, 2009 | 1991 Ford F150
    Need factory stereo color codes
    best way is to get in the with a multireader and find a constant power and a ignition, for the speakers, i use a AA battery with a wire on each end, to test the spekers, you will hear a pop from speaker, so you can find which wires go to what speaker.
    May 05, 2009 | Car Audio & Video
    I need a diagram for the factory stereo wiring on a 1999 ford f150. I need to know what color the speaker wires are and the memory
    1999 Ford F Series Stereo Wiring Constant 12V+ Light Green/Pink Switched 12V+ Black/Purple Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
    Dec 30, 2008 | 1999 Ford F150 Regular Cab
    Car Audio & Video Logo
    77 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
