Question about Dell Inspiron 1545 Notebook
When I try to syslinux on my usb stick using command "syslinux -ma h:" (well, my usb stick's letter is h), its showing access to physical drive denied.Did not successfully update MBR . so how should i install syslinux? Well am actually trying to install ubuntu on another computer using usb stick, my laptop is running windows 7 eternity edition
  • 22 Answers
To boot from USB stick you should convert it normal disk to MBR(Master Boot Record) disk.Convert it first then you can boot from USB stick.
Posted on Oct 01, 2010
Sss i forgot my email and password
Don't know about your email but if its a Windows password you have lost go here http://pogostick.net/~pnh/ntpasswd/ and download the "Windows Change Password / Registry Editor / Boot CD" from the link Password reset CD/USB bootdisk: Instructions & image to download.
NOTES
"The password reset and registry edit has now been tested with the following:
NT 3.51, NT 4, Windows 2000, Windows XP, Windows 2003 Server,
Vista, Windows 7 and Server 2008.
As far as I know, it will work with all Service Packs (SP) and
all editions (Professional, Server, Home etc)
Also, 64 bit windows version (XP, 2003, Vista, 2008, Win7) shold be OK.
To make a bootable USB drive / key:
1. Copy all files from this CD onto the USB drive.
It cannot be in a subdirectory on the drive.
You do not need delete files already on the drive.
2. Install the bootloader (you may have to be administrator)
On the USB drive, there should now be a file "syslinux.exe".
Run this from a command line, like this:
j:syslinux.exe -ma j:
replace j with some other letter if your USB drive is on another
drive letter than j:
On some drives, you may have to omit the -ma option if you
get an error.
If it says nothing, it probably did install the bootloader.
Please note that you may have to adjust settings in your computers BIOS
setup to boot from USB.
Also, some BIOS (often older machines) simply won't boot from USB anyway.
Unfortunately, there are extremely many different versions of BIOS,
and a lot of them are rather buggy when it comes to booting off different
media, so I am unable to help you."
Feb 01, 2014 | HP Compaq Presario V2000 Notebook
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Unknown capacity usb
Run CMD.EXE as administrator
Type following commands and hit ENTER key after each command.
· DISKPART starts the DiskPart program
· LIST DISK shows numeral assigned to disks
note the numeral assigned to your usb stick
The numeral 2 will be used in this example
· SELECT DISK 2
· DETAIL DISK the info shown will confirm the correctness of your selection
· CLEAN ALL the entire usb stick will be overwritten with zeros
· CREATE PARTITION PRIMARY create a primary partition on the USB stick
· FORMAT FS=NTFS format the partition
· ACTIVE the partition can contain operating system startup files
· ASSIGN the next available letter is assigned to the USB stick
· EXIT exit from the DISKPART program
· EXIT exit from the command shell
Nov 08, 2013 | SanDisk Electronics - Others
Pendrive install ridata
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
In the below image my USB drive disk no is Disk 1.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
Oct 03, 2013 | Computers & Internet
Forgot my password on my compaq
You can delete your password using this tool:
http://pogostick.net/~pnh/ntpasswd/usb110511.zip
Just open that URL and it will download to your computer. Open the .zip file and copy all of the contents to a USB drive, like a flash drive. Then open the command prompt (Start > All Programs > Accessories > Command Prompt) and enter the following:
X: syslinux.exe -ma X:
Except, instead of X:, enter the letter of the flash drive. (When you're looking at "My Computer," it should say the name of the drive with a letter like F: or G:, that's the letter you use.)
Now you have to boot your Compaq from the USB drive. Plug the flash drive into the Compaq and turn it on, but you have to enter the settings. (Every computer is a little different here, it will tell you a command for setup. Enter this.) Follow the instructions on the screen to get to the Boot Order, and move USB to the top. Then Save and Exit and let your computer start. Follow the on-screen instructions with this program and just delete the password. Once this is done, exit the program properly, restart the computer, made the Hard Drive the first thing to boot from in the settings again, and just hit enter when it asks for a password. You should be in!
If you have any other questions about the program, the walkthrough and FAQs are on this page: http://pogostick.net/~pnh/ntpasswd/
Mar 11, 2013 | Computers & Internet
Erc410m usb boot support
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Nov 17, 2012 | Computers & Internet
Can i make a bootible usb for my dell diminsion 2400 i get a disskette 0 error seek failure
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
hope it helps
May 19, 2012 | Dell Dimension 2400 Desktop Computers
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
Dell Inspiron 1545 Notebook Logo
466 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
