Question about Kenmore Sewing Machines
The feed dogs don't seem to be guiding the fabric through. I'm not getting an even stitch and sometimes it just stays in one spot, even though I'm guiding it. I've been gently pulling it from behind to help things along, but the stitching is very erratic. I've check the that the feed dogs are up and they are. Any suggestions?
  • Kenmore Master
  • 7,365 Answers
Is the presser bar applying enough pressure on the fabric to help the feed dogs do there job
Posted on Oct 01, 2010
  • jackie_lo702 Oct 01, 2010
    I don't know. The presser bar may be the answer. Thanks for the suggestion.I'm going to take it to a repair place and have it checked out.
My Singer Quantum 9960 doesn't seem to be moving the material when I am sewing. It sews in the same spot and then the material gets stuck.
Am guessing you've already verified the feed dogs are in the raised position. The other thing to check is the presser foot pressure. If you are sewing lighter weight fabric, you may need to increase the pressure to make more contact with the feed dogs, or lighten the pressure when sewing thick fabric. Something else that may help is using a roller, teflon, or walking foot.
On the other hand, if the feed dogs are not moving like they should even if you have the stitch length higher, your machine may need service. Be sure you've cleaned the feed dogs of any accumulation of lint, dirt, debris. Of course, if you have used the machine a lot, the feed dog points do wear so they may not be gripping like new.
Jan 16, 2017 | Singer Sewing Machines
Won't ewd fabric through. It just stays in the same spot.
Google make find mfg's website and get tech support . or take it to a repair shop .
Dec 25, 2016 | Sewing Machines
Why when I sew the fabrics not advance even if the claws are raised and the machine does not stop sewing. I have to close the switch
With the issues you are experiencing, it may be wise to take it for service.
Even though the feed dogs are raised, are they actually moving forward and back as you stitch (remove the thread, raise the presser foot, rotate the handwheel, and watch the feed dog action)? Check that the stitch length is set long enough that the feed dogs will be moving the fabric rather than sewing in place. Another thing to check is whether there is a pressure adjustment for the presser foot. If you are sewing light weight fabric, sometimes the pressure needs to be increased so the feed dogs are able to grab the fabric.
As for the machine running on, it could be a multitude of issues, ie the foot control, electrical... This may be something that a professional should evaluate.
Jun 22, 2016 | Janome Memory Craft 9000 Computerized...
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
Feed dogs will not engage. What to do?
Are the feed dogs in the raised position and not dropped for darning for free motion quilting? Is the stitch length set to somewhere between 10 to 12 stitches per inch? If the stitch length is set too close to zero, the feed dogs will barely move the fabric causing it sew in the same spot.
Feb 21, 2016 | Sewing Machines
My sewing machine seems to do the same stitch length if I set it on 1 or 4 it doesn't change. I also have to pull the fabric along as the machine does not move it, just sews in the same spot. The machine...
There are a couple of things that could cause this. Your feed dogs could be either low or worn down, so they are not biting into the fabric enough to move it. The presser foot pressure could be set at it's lowest setting and not pressing the fabric firmly against the feed dogs, thereby allowing the feed dogs to slip under the fabric without moving it. You could also have a lubrication issue or a broken part in the stitch length adjustment system. In any case it would probably be best to take it to a reputable sewing machine repair shop in your area for a tune up. That's a great idea anyway after buying any machine second hand.
May 02, 2014 | Janome Sewing Machines
I have an Elna 2730. the feed dog is not transporting the fabric anymore and the needle just keeps stitching in the same place. is it broken or just needs adjusting?
if you have a manual, look to see where the feed dogs are, if the lever for the feed dogs is in the up position then the machine will sew a straigh stitch
if the feed dog lever is in the down position then it will only stay in one spot,
if you try to push the lever up and it will not stay or stays and will not sew then the feed dogs need to be checked
Oct 09, 2013 | Elna Quilter's Dream 6003Q
I have a Bro PE 400 D. The feed dogs do not seem to be pulling the fabric through without me pulling on it. Stitches are very small even when put on a longer stitch. Embroidery Unit works fine.
check the feed dogs under the needle plate to see if there up or down
if there down then the feed dog switch need to be moved to the up position
but if there up,,,then the machine needs to be serviced so the feed dogs & stitches can be checked
Aug 26, 2011 | Brother Disney PE-400D Computerized Sewing...
Why does the backing gather up even though it is penned and sprayed with quilting spray
Presser foot tension is to low for the weight/finish of the fabric, or bottom dogs are worn.
  • The feed dog feeds the fabric under the presser foot while you guide the fabric.
  • The feed dog regulates the stitch length by how much fabric passes under the presser foot as the machine stitches.
  • It is important for you to not push and pull the fabric under the presser foot. Allow the feed dog to move the fabric, so that you do not bend and break sewing machine needles.
Hope this helps.
Feb 09, 2011 | Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Sewing Machines Logo
179 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
