Question about LG DVD 6183 DVD Player
Shows Loading menu after switch ON and nothing comes out as results
I'm using LG DVD Player for the past one year. Now there is a problem in my DVD Player. While switch on the player, it shows Loading menu (After CD Inserted) for a long time and will not produce any results after that. It seems that the DC Motor in the DVD Driver is not working and CD is not spinning to produce the output. So please any one help me to debug this and correct this issue.
  • holder_siva May 26, 2008
    Thanks for your immediate response. I tried to run the DVD that was working fine initially. But now the problem (Hopefully) with the driver motor. Since the DVD is not spinning after loading into the drive. This I checked and confirmed after removing the cover of DVD player while trying to debug the problem myself
  • holder_siva May 29, 2008
    Thanks for your information. Will do as per your suggestion. But before that, i want to have circuit design of this particular DVD Driver circuit to debug the same. So Please clarify me whether we can get the schematic for this particular section of DVD Player which will help me a lot to debug and fix the problem
I had a problem like this. My DVD player would say "loading, loading" forever before saying "Cannot read this disc." I opened the case (carefully) used Dust Off to blow out the tray and laser area. Unit works fine now and I learned a valuable lesson: CLEAN PERIODICALLY. Actually, a basic lens cleaner used regularly will probably eliminate the need to open the case and perform air surgery.
Posted on Jul 18, 2008
That a good way to figure out the problem, so if you confirmed that the disk is not spinning then it is a problem with the drive or the component thats supplying power to the drive, i would suggest to replace the drive after testing out the power suppy
Posted on May 29, 2008
  • 4 Answers
Looks like it has a problem reading the disc
what sort of disc are you trying to play
try with an original DVD and see the results
Posted on May 26, 2008
My LG dv490h DVD player has its DVD drawer jammed open. When I press the button to close, it goes 20% of the way in and stops. My one year old pulled the drawer open this morning. Have taken the cover off...
The DVD tray has come off the alignment or settings which make it come OFF the mechanism. So you will need to push back the drawer back to the set position and this might be possible only after the loading mechanism is pulled out. The loading gear would have meshed with the loading drawer at mid way -due to the pull--and so it connecting only half way.
If mechanically minded you can remove the tray mechanism and reset the tray to the gear position in the DVD play/stop position.
Feb 04, 2011 | LG DVD 6053 DVD Player
Dvd will not load
the laser lens of the player is weak, the lens is trying to load the data on the disc, but its too weak to accomplish that. So it keeps loading.
Get a lens cleaner and use it to clean the lens, but it that does solve the problem, you will have to replace the lens entirely.
Good luck.
Jul 21, 2010 | Initial IDM-1731 Portable DVD Player with...
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Dvd player thinks it's loading a dvd but there is no disk in the player. it won't stop trying to load after turning power off, ejecting, etc
Unplug the TV.
Use a flashlight and look inside the player you may see a DVD or a label from a DVD inside.
If you are sure theri is no DVD stuck in the player then the player may need to be replaced..
Contact LG @ 1800 243-0000 The TV has a 1 year full warranty.
If you are past the 1 year they may help you with the repairs just be patient and polite.
Jan 13, 2010 | LG 32LG40 32 in. LCD HDTV
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
Will not play CD's at all
you need to clean the pick up laser i had same problem
Feb 17, 2009 | Denon DVD-2200 DVD Player
DVD PLAYER
hai ashis .
this problem lies on your powercord(mains wire)
or else power supply bord inside of dvd unit mostly power supply switching is gets defetive replase it with same type
all the best.
by
yvsharma
Sep 23, 2008 | Electronics - Others
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
Please wait
try to clean loading sensors
Jun 03, 2007 | LG RH-4820 DVD Recorder
LG DVD 6183 DVD Player Logo
130 people viewed this question
Computer Repairing
Computer Repairing
