Asko 10505 overflow problem
I have a problem with an Asko 10505 front loader washing machine. When it gets to the rinse cycle it very often (but not always) won't stop the water inflow so it overfills, overflows and floods the laundry. I'm guessing that there is some sort of a level switch which isn't being activated although it's strange it only does this on rinse, never initial fill.
Any ideas?
Thanks,
Graham
  • grl570810 May 26, 2008
    And I'd find the water valve about where in the machine? I'm a real appliance dummy !
Anyone know where the water valve is? Thanks.
Posted on Jun 04, 2008
  • 868 Answers
Replace the water valve and your problem is gone.
Posted on May 26, 2008
My washing dries coarse since I purchasing my Asko front loader. Towels and socks in particular. What can I do to stop this from happening?
Use a washing softner in the final rinse water such as Downey Apparently you have hard water that lealeaves precipitated minerals in your clothes.
Feb 05, 2011 | Asko W6661 Front Load Washer
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Feb 19, 2010 | Asko Washing Machines
When my machine gets to its rinse cycle it works for about 30 seconds and then all the lights start flashing and it stops working
You most likely have a faulty cold inlet valve. When the machine gets into the rinse cycle, it needs to fill up with cold water.
Depending on whether you have a top loader or front loader, there may be a seperate valve for the rinse water intake on a front loader.
Let me know the make and model of your machine and I can help you identify and replace the inlet valve.
Regards
Ash
Nov 15, 2009 | Washing Machines
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Need information about an old ASKO 10604 washing machine
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Jan 23, 2009 | Asko W6021 Front Load Washer
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Washing Machines Logo
283 people viewed this question
Top Washing Machines Experts
