Computers & Internet Logo
Posted on Oct 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Graveur cd/dvd r rw ne marche plus hitachi hts 54032b9a300
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Oct 01, 2010
Master
Level 3:
Answers
6993
Questions
Helped
1700511
Points
1261
this question is not clear enough. Can you please rephrase the question so that an accurate solution can be proffered?
What precisely is wrong with your CD/DVD RW?
I look forward to your reply.
Bye for now.
I cannot connect the usb to my lap top it does not recognize it
u menia Sony DCR-DVD101E DVD-?²?¸?´?µ?¾???°?¼?µ???° ho moi kompiuter\toshiba satellite a200 windnows vista/ne chitaet disk etogo camcodera.i ne mogu instalirovat driver sony usb CD-R/RW diskoveda please help me
Aeg 72620 affice code cd et ne démarre pas
error "cd" means door lock defective although I have found that the main electronic board is uaually the fault and not economic to repair.
Bonjour, novice en PC mon lecteur DVD/CD-RW ne
because on dust try to replace to a new dvdrw
1helpful
My E drive is not working. how can i fix it.
Have you tried cleaning the laser assembly? If your OS still sees the drive then it may just be having trouble reading.
Try this
First try to boot from your xp cd. If it fails to boot from the cd then your drive is screwed. If it does boot from the XP cd then ONLY try the following
Click Start.
Click Run.
The Run dialogue box appears.
Type devmgmt.msc in the run dialogue box and click OK.
Click on the plus sign next to DVD/CD ROM Drives.
Locate your DVD/CD ROM drive in the list of devices.
Verify the type of drive in your computer and that the type of media you are using is supported by the drive. Use the table below to determine the supported media types.
DVD+/-RW Read CD or DVD media, write DVD+RW, DVD-RW, DVD+R, DVD-R, CD-R, CD-RW media.
CD-RW/DVD Combination Drive To read CD or DVD media, and write CD media.
DVD-ROM Drive To read CD or DVD media.
CD-RW Drive To read and write CD media.
CD-ROM DRIVE To read CD media.
Try cd drive now before trying the next step
Click the Start button, right-click My Computer, and click Manage.
The Computer Management window appears.
Click Device Manager.
Click the (+) plus IDE controllers section.
Double-click the appropriate IDE channel.
The IDE Channel Properties window appears.
Under the Advanced Settings tab, verify that the transfer mode is set to DMA if available.
Click the OK button to save the change. At this point, you may need to restart for the change to become active.
Check to see if the drive will work in safe mode. I it still does not work Update the firmware for the optical drive.
Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
If all these steps fail then you will need to replace your drive.
Thank you.
3answers
What dvd do i use for philips dvd recorder r610 is it plus or minus can you please answer this
Depends how its marked if its DVD-RW it use minus, if its DVD+RW its uses plus. If its
DVD-RAM its for DVD+/-RW (and CD-R, CD-RW, DVD+/-R).
Problem with Optical Drive SONY DVD RW AW-Q170A
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
1helpful
4answers
LG powerDVD installer
lg powerdvd version-5 was installed in my hp-pc, but the dvd player is not working properly. some time it stopped in playing cd or dvd .please help me.tarun dutta.
Hitachi-lg cd-rw gce-8487b device driver corrupted or missing error code 39
You may find your driver here: http://us.lgservice.com/ or here: http://www.kauaikeepsakes.com/computerguy/
Good luck
My Ricoh Mp5120A(which isn't on the list) DVD+RW & CD+RW burner
some drives can only read plus disks and not minus as well im afraid
Grand Canyon Tech
Grand Canyon Tech
