Question about Back to Basics 700 Smoothie Pro Work Top Blender
Broken pour spout
My daughter broke the pour spout handle at her graduation party, where do I get repair parts or a new spout.
  • carabelita Feb 16, 2009
    I need to replace a broken pour spout.
    The rest of the unit works perfectly.
    How do I order a replacement spout.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
If you want me to tell you how I fixed my problem, there will be a $20.00 charge for that.
Posted on May 27, 2008
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
The handle to the pour spout on the bottom of the blender has broken off. So I can not put smoothee in my glass. I have to pour it in my glass for the top of cannister. Where can I get replacement parts?
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have the smoothee spout. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Oct 16, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Spout is broken on the villaware smoothee-bar blender. Looking for a replacement part.
Oct 05, 2009 | VillaWare 5785 Smoothee Bar Work Top...
The pour spout on my Back to Basics Smoothie Freeze has completely cracked off. Where do I get a new container with valve and pour spout?
I am looking for the dispensing valve for my BackToBasic. I'm not sure but I think it is a 700. It is a black dispenser with a chrome base. Please let me know if this part can be replaced. I could settle for a white one but it would look like a "saddle on a donkey" as my husband would put it.
Jul 06, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Back to Basics 700 Smoothie Pro Work Top Blender Logo
2,183 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
