I have two Samsung Room a/c's model AD18B1C09 that are having problems. these are the 2 inside units. I turn them on and it starts but after a few seconds they shut off and 2 lights flash green and orange
5 Suggested Answers
SOURCE: Power Issue
check the water stored in the aircon unit. if the water is full the unit will shut off with a beep. try to pull the plug and release the water. now try to switch it on
Posted on Jul 09, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
SOURCE: Green Light on unit is flashing every 6 seconds
my lg unit (indoor) green light flashing 5 times
Posted on Aug 11, 2010
What do the letters "DEW" mean on the screen. TV/VCR combo model GOJ 12330
DEW means that there is condensation inside the unit. Turn it off and unplug it for a few hours. The unit needs to reach equilibrium with the temperature and humidity with the room. The TV is cooler than the room and the moisture will continue to be a problem until the components of the TV reach room temperature.
If you fail to allow the TV to reach equilibrium, some components may become damaged by the moisture. If that has happened, resolving the error may take major repairs. Electronics do not like moisture.
I hope this helps.
Jan 23, 2015 | Televison & Video
Error fan check message always appear when you turn the DVD on
Page 32 of the manual:
http://www.retrevo.com/support/Samsung-HT-Z510T-Home-Theater-Systems-manual/id/14714ci454/t/2/
Cooling Fan
The cooling fan supplies cool air to the unit to prevent overheating.
Please observe the following cautions for your safety.
Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit may rise
and may damage it.
Do not obstruct the cooling fan or ventilation holes. (If the cooling fan or ventilation holes are covered with a
newspaper or cloth, heat may build up inside the unit and fire may result.)
So look at the fan and make sure it's turning. Pick out the dust balls. Give the system room to breath (Page 13: 4" clearance from the fan)
Feb 07, 2011 | Samsung HTZ-510 Theater System
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Hi there. I have a problem with my Rheem Classic
my friend it sounds like you have a bad motor the compressor will lock out either on hi pressure or internal overload start with the outdoor motor good luck
Jul 19, 2009 | Heating & Cooling
TV SHUT S ITS SELF OFF
Is the unit free of dust and debris from dust? If its overheating there are may factors that play in this
1. fan spinning but not enought RPM rotations per min ( not fast enough)
2. room temp
3. dust
other then that some capictors must have exploded inside withc will cause a overheat.
Apr 22, 2009 | Samsung HLR5064W DLP Projection TV
Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Feb 11, 2009 | Samsung Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Whirlpool A/C Model #ACQ158XP
Unfortunately, your model does not have a fan belt so you may need to have it serviced by a technician. Prior to calling one, clean the room air filter and hose off the coil from the outside if you can get to it. Unplug the unit first. The squealing may be a dry bearing in the room air fan. If you can get to the fan, put 2 or 3 drops of electric motor oil on the fan shaft and work it into the motor housing by hand. Make sure you are getting power at the outlet. If so and the unit does not show any signs of life (lights or a fan), probably the fuse inside the unit has blown and will need replacing. Good Luck.
Sep 26, 2007 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
