Question about Whirlpool Duet GHW9150P Front Load Washer
IT WAS MAKING A HUMMING NOISE AND FLASHING F20 SO I JUST SHUT IT OFF AND UNPLUGGED IT
  • 2,382 Answers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the "F20" error code.
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free.The pump is located directly under the wash tub in the front of the washer.Verify the electrical connections are good and that the pump is running.Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer.With the screws removed, the panel should slide back, then, lift off.The pressure switch is located on the right-hand side of the washer in the rear.It is a round plastic device with electrical connections and a plastic air hose attached.Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub.There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls.Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU.In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Posted on Oct 01, 2010
  • dlgordoni Dec 07, 2010
    This was extremely helpful, thank you! My F-20 code was solved! We simply followed the instructions, removed the bottom front panel, and cleaned out the pump. It had a bunch of junk in it, including money!;-)
  • Tunde Autos
    Tunde Autos Dec 07, 2010
    My humble pleasure sir!
    Am so glad that it solved your problem.
GE PROFILE refrigerator.. Has been unplugged for months. I plugged it in & it's making noise. Unhooked water supply yet still noisy..
What kind of noise, that makes a difference, a humming is a bad compressor, a rattling could be bad relay or start capacitor, or bad groumets ( the rubber pc.'s that compressor sits on) also a bad condenser fan could be making noise ( its located next to compressor. see pics
Dec 23, 2016 | GE Refrigerators
Making a soft humming noise on start up and shut off
If you have a device connected to the tv.please disconnect them all.try connecting tv directly to a power outlet.can u elaborate the humming noise.
Dec 31, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
My rheem 90 plus, has a humming noise any time the power switch is turned on even with thermosat unplugged. i shut the switch off and it stops. do i have a short some where?
Hello, typically a humming noise comes from the transformer located in the blower section of the Furnace. Sometimes it is caused by the transformer being loose, and others it can be a sign of the transformer going bad. i would make sure that it is secure first and see if that helps.
Oct 28, 2011 | Heating & Cooling
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
The motor has gone bad on your dryer...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | LG DLE2512W Electric Dryer
IHome lamp has a humming noise
Hi, I would suggest you exchange it for a new one under the 6month warrranty it has.
I have several iHome Lamps and I dont have a humming noise from any. I know its annoying but its an electrical item and sometimes they go wrong.
Dec 09, 2008 | Blue iHome Desk Lamp with iPod/mp3 Dock,...
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
