Question about Toshiba Satellite A105 Notebook
I have no sound - checked volume control and it says no sound device
  • 22 Answers
Driver currupted problem.uninstall it ,and then installing new driver may fix this problem.
Posted on Oct 01, 2010
Hello, im using sony vaio VPCEB3J1E,speaker is not working but head is working,what is the problem?
For Vista/windows 7
Check with volume settings.
Right click on the speaker icon in taskbar and select volume control options.
Put a check mark on "All devices currently playing sound".
Make sure you have "The default communication device unchecked".
Place a check mark on both speakers and headphones.
For Windows XP
- Speakers, Headphones
In "Control Panel", select "Switch to Classic View", and open "Sounds and Audio Devices".
In "Sounds and Audio Devices Properties", click the "Audio" tab, and click the "Volume" of "Sound playback".
On the "Master Volume" screen, click "Properties" in the "Options" menu.
Add a check mark to "Playback" of "Adjust volume for" on the "Properties" screen, and check marks to "Master Volume" and "Wave" for the control to be displayed, and click the "OK" button.
On the "Master Volume" screen, remove the check marks from "Mute all" of "Master Volume" and "Mute" of "Wave".
Note: The settings may differ depending on the PC you are using. Please check items such as sound in the manual for the PC you are using.
May 22, 2011 | Computers & Internet
DOES NOT RECORD ANYTHING ON MY WINDOWS XP
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
I installed my interface, but my recording software still isn't picking up sound from my mic
You may need to enable the microphone in control panel - see below
You will also need to check the correct sound source is selected in your recording program.
Click VOICE
That should be it.
Feb 18, 2011 | AKG Perception 220 Professional Microphone
My computer will not see or hear sound from my microphone but i know it works
Click VOICE
That should be it.
Feb 17, 2011 | Labtec Verse-514 Consumer Microphone
How to unmute laptop sounds. Its mute and i am not able to unmute it?
  1. Click START
  2. click CONTROL PANEL
  3. click SOUNDS and AUDIO DEVICES
  4. Look at the box labelled SOUND RECORDING - if the DEFAULT DEVICE is listed as WAVE DEVICE (may have some letters and or numbers in front of the words WAVE DEVICE - they are only the name of the device) go to step 6 otherwise click the little downward arrow at the right hand end of the DEFAULT DEVICE box. Scroll down the pop-up list to WAVE DEVICE and click on it.
  5. click VOLUME in the SOUND RECORDING box
  6. A window will open entitled 'Recording Control'
  7. Put a tick (check-mark) in the little white box under the heading of MICROPHONE and make sure the Volume slider is at the top of the scale.
  8. Close the window to go back to the Sounds and Audio Devices Properties Window.
  9. If you also want to hear what you are saying into the microphone over your own loud-speakers / headphones click on the VOLUME button in the SOUND PLAYBACK box.
  10. A VOLUME CONTROL window will open. If MICROPHONE is in the list of sound sources go to step 11 otherwise click OPTION on the tool-bar at the top right of the VOLUME CONTROL window. Then click PROPERTIES. With a little green dot in the PLAYBACK box look where it says 'Show the following volume controls' - place a check-mark against microphone and then click OK
  11. In the VOLUME CONTROL window remove any check-mark from the MUTE box under the MICROPHONE heading and also make sure that the MUTE ALL box (bottom left) is also un-checked.
  12. Close the VOLUME CONTROL window. Press OK to close the Sounds and Audio Devices window and exit CONTROL PANEL
  13. That should be it but if you are using MSN Messenger / Skype or other similar program you will need to start that program and click on the TOOLS button followed by SOUNDS and TEST AUDIO - follow screen prompts thereafter.
Jan 30, 2011 | Toshiba (P000257700) Microphone
I have lost my sound on my desk top pc how do i retrive it bk again
maybe you selected the wrong sound driver. go to control panel. go to sounds, speech, and audio devices. go to sounds and audio devices. go to audio. sound playback, check the device and if diffrent change it and see if that works.
your main volume on all channels where droped. some applications can cause this to happen.
go to start. all programs. go to accessories. go to entertainment. volume control. ensure the volume is up on there. Then if it has it on your volume controll. click on speaker volume that is over top the main volume controll. and make sure your computer speakers didn't drop volume.
make sure the mute is not checked
Oct 25, 2010 | Computers & Internet
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
independently controlled for all programmed devices.
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected
Mar 15, 2008 | Polaroid FLM-2632 Television
Toshiba Satellite A105 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
