Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Have a moen single handle in the shower, cartridge needs to replaced. Took the screw out, plumber cannot get the handle off. Told me to call Moen. I did, it is nine years old. Do not have model #. They told me it would have to be cut off and replaced. How do I get the handle off?
  • 26 Answers
Hi cgra--
Two ideas:
1) Shoot a little penetrating oil into the area around the brass screw hole and anywhere else you can see where the handle contacts the control stem. Then gently wiggle, push/pull, and/or tap until it seperates. If you can get a long, narrow flatblade screwdriver behind the handle, you can try that as a prybar, too. When the handle does come off, get it into a bath of soapy water immediately--the penetrating oil may melt the plastic.
2) Go to your local hardware store and look for a faucet-stem puller. The puller works much like a gear or bearing puller, but without lots and lots of torque. You may want to use a dash of penetrating oil again before using the puller. You could also substitute a large puller--if one is handy--while only using a GENTLE pulling force.
A final note. If you do apply penetrating oil and nothing frees up, liberally wash the handle until that oil is gone. The plastic could melt and only tighten the handle where you don't want it.
--Hope this helps
Posted on Oct 07, 2010
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
Single head scald resistant shower fixture. Needs new cartridge. Took screw out plumber cannot get handle off. Called moen it is a 2001 model. But they said cannot help me. Need to cut off and get new...
There are several products that can be used to loosen the corrosion holding the handle in place. The Works is one product along with CLR. The easiest fix is to wrap a washcloth soaked in distilled white vinegar around the handle. Let it soak for 20 minutes at a time. It could take a half dozen times or more, but eventually it will work. Rinse the faucet after each application to remove the acid. You may also need to use this process to remove the Moen faucet cartridge.
Oct 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
Moen single handle shower faucet, contstanly drips
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Mar 12, 2009 | Home
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
100 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
