PHILIPS 42PFL3603D/F7. ISSUE: TURN UNIT ON AND THE PICTURE IS GOOD. LET RUN AVERAGE OF 30 MINUTES AND THE PICTURE GOES MULTI-COLORED (CAN SEE THE OUTLINES ALMOST AS IN A NEGATIVE PHOTO). LET RUN AND THE PICTURE AFTER ABOUT 30 MINUTES - AN HOUR (TIMES VARY) PICTURE CLEARS UP AGAIN. THIS PATTERN JUST KEEPS REPEATING. PLEASE ADVISE TO THE CAUSE AND CORRECTION OF THIS ISSUE
  • 10,594 Answers
This kind of problem is related with lcd panel (screen) of tv and some times T-Con board found defective, cause of problem.
T-Con board is part of lcd panel however some parts stores sell it separately.
Philips 42PFL3603D/F7 utilized two type of lcd panels and t-con boards are also different depending on lcd panel, if you are familiar with electronics stuff repair then can attempt to replace t-con board as it might fix your tv problem and if you have no experience then I would recommend to have tv repairman services. T-Con1 and T-Con2 are available with shop jimmy, click links to see image of boards and price info.
If T-Con board replacement didn't fix the issue then complete lcd panel (screen) will be replaced, it would be costly fix like approx 80% of new tv price.
If tv is still under warranty then do not attempt for any thing, just call number written on tv warranty documents and ask for warranty cover.
Let me know if you have additional question.
Thanks.
Posted on Oct 01, 2010
How do i replace part number 932224306671 on a philips 42pfl3603d/f7
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Philips Televison & Video
Turned on my Philips 42pfl3603d/f7 and you can see the images but everything is blue what part went bad and can I replace it my self
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
MY PHILIPS MODEL 42PFL3603D/F7 TURNS ON WHEN YOU PLUG THE POWER IN AND THE BUTTONS DO NOT WORK
If the remote works for the set, both it and the buttons on the set go to the same place in these sets.
The Keyboard with the manual buttons may have a lockout feature--it can be locked to prevent children etc from tampering with the controls.
If no function from remote, that could be same issue or another==key board has priority over the remote control.
if all else fails carefully read the owner manual.
May 24, 2012 | Philips 42PFL3603D 42 in. LCD TV
Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Sep 27, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
Electro Med Services...
