Question about IBM ThinkPad A20M Notebook
IBM a20m ram issues
I have recently bought two 256 mb of ram for my laptop. When I installed them and tried booting up. I kept getting a windows error and to try to fix it with my windows disk. I said to restart the computer and push "R" at the first screen. It just said windows error code 4. I put my two pieces of 128 mbs of ram back in it and everything worked right. I checked and the two 256 mbs of ram are suppose to be the right ones.
    Scholar:
  • 110 Answers
If they are compatible but your machine isn't happy with them, it sounds like they're faulty. Return both sticks to the retailer and ask them to replace both, just in case they replace the good one and give you the faulty one back.
Posted on May 26, 2008
I have a Toshiba Satellite A10-S129. It was working with 256 MB (2 x 128 MB). I wanted to upgrade it to 512 MB (2 x 256 MB). I bought 2 new 256 Modules and when changed it and turned on screen has...
If you get several beeps then there is a video problem. The video card uses shared RAM (part of the main RAM) and if the RAM is faulty the laptop won't boot up.
You might have incompatible RAM, try to use the same make and speed RAM as the original.
One of the RAM modules may be faulty.
Try installing one 256Mb RAM module then boot up the Toshiba, if it works the try the other RAM module.
Mar 20, 2011 | Toshiba Satellite A10-S129 Notebook
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
Does not install on 64bit systems
Please read the System Requirements Carefully.
60-day trial does not include technical support and requires the following:
  • PC with 300 megahertz or higher processor clock speed.
  • Windows Vista® with 1 GB RAM, Windows® XP with 256 MB RAM, Windows Server® 2008 with 512 MB RAM or Windows Server 2003 with 256 MB RAM -> (64-bit versions of Windows XP and Windows Server excluded); service packs for operating systems recommended.
  • Certain features require Internet Explorer®. If not present, Internet Explorer will be installed but will not displace your primary browser.
  • Available hard-disk space: 1.8 GB (some users may require up to an extra 300 MB).
  • For installation of software: DVD drive or high speed Internet access.
  • Super VGA (1024 x 768) or higher resolution monitor.
  • Microsoft Mouse, Microsoft IntelliMouse®, or a compatible pointing device.
Thats the System Requirements for the Trial Version. I am not sure whether you are running Windows Vista or Windows 7. You cannot install this on WINDOWS XP/Windows Server 2003 which have 64BIT Architecture.
Same applies for the 2009 Version as well.
You can update it to work with Windows 7 from here. You can update it to work with Windows Vista from here. Search by the Name under Software category.
Feel free to contact me if you need further instructions. Please be kind enough to Rate the answer as well with a comment if it solved your issue.
Thanks for contacting Fixya!
Jun 11, 2010 | Microsoft Streets and Trips 2008 for PC
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
After adding 256 MB with existing 256 MB showing only 256 MB in BIOS instead of 512 MB
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
Jan 07, 2010 | IBM ThinkPad T30 2366 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
Cannot install 6940 driver
this is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Apr 21, 2009 | HP Deskjet 6940 InkJet Printer
I have an ibm a20m 700 speed. installed 2 256 ram does not work
I REALY DEPENDS HOW MUCH THE VENDER SET THE SOFTWARE AND HARDWARE WILL SUPPORT
MY NEW LABTOP HP DV9000 CAME WITH 2GIG
AND THEY SAID 3GIG OKAY BUT WE RECOMMAND 4GIG RAM BECAUSE YOUR VIDEO RAM SHARE THE RAM UP TO 799 MB
RAM, SO SHARE VIDEO RAM AND MEMORY RAM, WHEN ALL IN DONE AND THE COMPUTER DOES ALL IT CALCULATION IT SAYS I HAVE 2-3GIG RAM AVAILABLE TO RUN OTHER SOFTWARE
ALSO WHEN YOU GO TO PRICE IT 1-2GIG CHIP MAY COST 50-100.00 DOLLARS
AND A SET OF 2-2= 2 PEACE OF RAM EACH ONE HAS 2GIG OF RAM
A SET MAY COST 40-140.00 DOLLARS
YOU NEED TO KNOW IF YOU NEED DUAL CHANNEL
PARITY AND NON PARITY
ASK ALOT OF QUESTIONS FROM THE VENDER FIRST
THAN GO TO WWW.FRYS.COM
RODGANDYSR
Jan 25, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Ethernet driver does not work for IBM Thinkpad A20m
hi good day to you I have problem in my laptop thinkpad A20m PIII 700mhz 256 ram running in widows XP,, and everytime I install the driver of Lan the massage appear error in code 10, and the lan is not working,,can you help me in this problem?
Jan 12, 2008 | IBM ThinkPad A20M Notebook
Computers & Internet Logo
107 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
