Question about Car Audio & Video
I turned my car off and when I got back and turned the car back on the speakers made a weard sound for half a second when I put the key in the the radio started flashing protection. I tryed reseting it a few times and it would say standby for a sec then go right back to saying protection. What do I do???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try checking your speakers and speaker wires for grounds and/or shorts. make sure all your speakers are good.. if that all checks out, you may have a bad output ic inside the deck itself.
Posted on Oct 01, 2010
Hello I have a question, I have a cadillac 2002(sts) My car is not running I don't know what is the problem I put the key in and every times I turn in , it only make a weard sound but it doesn't run for...
I think I know what the issue.. This happened to my car. This site has a whole list of cars that have this issue.. they have a part that you can install yourself.. Hope this helps
Aug 01, 2014 | 2002 Cadillac Sts
What does a car do when goes in theft mode
The car will not be able to start with your own key. This reset is for ford cars. Press loud speaker icon on the remote entry key. The alarm will sound. Now put your key in the ignition and to it to the on position. This will reset the alarm. Now turn key to off position. Then turn key back to the on position. The securilock indicator on the instrument panel will light up for 3 seconds and then turn off. The securilock feature is now deactivated. Turn key to off. Then try to start the car with the key. This procedure should work for most ford cars.
Jun 12, 2014 | 1998 Ford Aerostar
1996 plymouth neon started and then died and now won't start
Go to your car and turn the key to the on position. You should hear a whine for about 2-4 seconds that is the fuel pump priming the fuel line. This sound will come from inside your gas tank, but you should hear it as you sit in the car or have somebody look under the car near the gas tank to see if you hear it. It will whine for 2-4 seconds and if you shut the key off and turn it back on, you should hear the whine again. If you don't hear anything, then it sounds like your fuel pump is out. If you do hear something then it might be ice in the gas filter or in the line somewhere.
Dec 02, 2013 | Plymouth Neon Cars & Trucks
I put the key in, turn to the second notch, the fuel indicator goes up to where it should be( bit under half) then goes back to below red and the low fuel light goes on( I know for a fact there should be...
hey there, your fuel pump seems to be bad. it will keep pressure while it gets that initial key turn as all fuel pumps kick in then but then loses pressure and doesn't kick in when pressure goes down. if the vehicle doesn't turn over try to tighten the terminal connections. good luck!
Feb 10, 2011 | 2003 Pontiac Montana
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
Sound in voices, videos, and games hesitates every second or second and one half and sounds like a sheep at the hesitations
Try updating your sound driver's this may help due to a bad driver.if you have a friend with a spare set of speaker's try them to rule out bad seaker's.Hope this helps.
Jul 26, 2010 | HP Compaq Computer Speakers
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
95 Lincoln Town Car Speaker Issues.
Turn on radio on half and get in the back seat and listen for distortion and if that dont work turn off the key unplug one speaker at a timeuntil you find it the wire are in the trunck connected to the speaker.Listen then not exceeding the power on the speaker and you wont need to turn it up that loud you will notice whats blown quickly.
Jan 13, 2010 | 1995 Lincoln Town Car
Take phone out of silent mode sgh p520
PUSH BUTTON ON LOWER RIGHT HAND CORNER OUNCE.
PUSCH SPEAKER BUTTON ON LEFT HAND UPPER CORNER FOF MORE THAN 2 SECONDS
May 21, 2008 | Cell Phones
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
