How to install a replacement ge a/c capacitor
The capacitor is not fitted in the unit and I can't remember how to hook up the new replacement capacitor. I need step by step instructions and especially how to connect the wires.
  • scoot50 May 29, 2008
    Yes, I just need to re-connect the capacitor and need to know where to connect the colored wires to the fan, the herm and C. There are 1 Yellow wire, 2 Orange Wires, 1 Black and 1 Red Wire and there is 1 Wire that comes off the Electric Cord. Where do I attach these wires ? Thanks.
  • kellyspeegle Jun 10, 2008
    how do i put the wires back on a capacitor on a widow unit please hep im soooooo hot
How to install a capacitor
Posted on Feb 18, 2010
I need instruction how to re-connect the capacitor in my GE window ac. the compressor control is also disconnected. there are 2black wires 1blue 1red 1 white and 1 from the electrical cord
Posted on Apr 27, 2010
  • 1,512 Answers
Oh sorry scoot, didnt see you ask. I have posted a heap of info to your original post. There is not much to worry about when installing the cap. The part is not polarity conscious, and the wiring generally falls into place in the correct spot to anyways. Have you got the unit apart yet?
robotek
Posted on May 28, 2008
  • Graeme Ross
    Graeme Ross May 30, 2008
    Ok, can you post a photo of the area for me to have a llok at it please. Is a little hard to make distinctions without actually seeing the area and wiring concerned. Awaiting your post :)
    regards
    Robotek
How do I change the lightbulb on a GE Monogram Microvae
The lamp is located inside the microwave housing which has to be removed to gain access for replacement. I agree with GE that removing the housing exposes you to dangerous voltages (even with power removed). The old lamp is removed from its socket and the new one installed, then the housing is reinstalled.
Mar 21, 2015 | GE Monogram ZEM200SF Microwave Oven
How to install a/c capacitor
hi scoot
Is a simple procedure, just change the existing capcitor for a new one. Do you have the old one still fitted to the unit? I will be able to steer you through it
regards
robotek
May 26, 2008 | Heating & Cooling
Tip
How to replace a microwave oven's diode:
Replacing a high voltage diode<br /><br />The first thing you must do to replace your microwave's diode is unplug the unit from the wall outlet.<br /><br />Next you will have to discharge the high voltage capacitor. A capacitor stores large amounts of electricity even when the unit is unplugged. It is necessary to discharge the high voltage capacitor in order to avoid receiving an electrical shock.<br /><br />Diode replacement is relatively straightforward because most high voltage diodes have a press fit, also known as Fast-On, or they have ring lugs. If your replacement diode can be installed either way, make sure you get the right polarity. Remember that a diode will conduct an electrical current when a forward voltage is applied, but when a reverse voltage is applied, there is no conduction.<br /><br />Remove the diode from your microwave and replace it with the new one. You may be able to crimp the new diode onto the wire leads, without welding or soldering them together. If you do crimp the diode onto the leads, be sure not to apply too much pressure, as this may cause connection problems either now or in the future. <br /><br />I hope this is helpful.<br />
on Dec 02, 2010 | Microwave Ovens
Is it safe to use a soft/hard start capacitor on my new Dometic Penguin 11,000 btu A/C ....Model # 640312.30X
No, the capacitor is not integral to the load of the generator, it is only used to start it when it turns on. It takes virtually no voltage from the system to recharge itself. The demand of the unit is not related to a start capacitor. Also it will not harm your unit to install one capacitor over another, they make them so if the connectors fit, they work. Just hook up the leads correctly so you don't discharge it on yourself.
Aug 27, 2012 | Dometic Rooftop RV Air Conditioner
My GE microwave model #JVM1640WB microwave stopped heating and is making a humming noise. Everything else about it is fine. Light, keypad, turntable, all work normally. Just no heat. How do I...
Hello, installing is quite straight forward if you know what youre doing. BUT, be very careful of the voltage in the capacitor even when its off,it is lethal! When you change the magnetron it is advisable that you also change the diodes. Again make sure that the capacitor is fully discharged, by switching the microwave off, unplugging it, and discharging the capacitor with an insulated screwdriver, it will be noisy. Next unsolder the old diodes and fit the new ones(check their polarity). Replace the magnetron and when all looks good,switch it on. If it works, good, if not there could be a power supply problem. 9 times out of 10 its the magnetron. Good luck.
Mar 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Unit fails to start
Make sure that you have selected the correct mode setting. If this is correct. You may need to replace the capacitor inside the outdoor unit (condenser). Open outdoor unit, usually removing the top cover (four or five screws) Make sure you have turned off all power to the unit. Locate the capacitor which is a cylindrical looking object with some spade lugs on one end. Take a snap photo so that you can remember how the wires are connected. Remove as a sample and buy a replacement and fit.
Nov 03, 2009 | Sanyo Split System Air Conditioner
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
How to wire a capacitor to a condencing unit
I can help you:
1: Put a Piece of Tape on each wire. write #1 #2 #3 etc
2: do the same on the capacitor.
3: Remove Wires with insulated needle nose pliers, and take a Insulated Screwdriver and Cross it over the Terminals on the Capacitor. Its safe, it just Discharges it.
4 Remove and go to lowes or home depot and get a new one.
5:Note the "RED" dot on the old Capacitor.make sure that you hook the same wire on the new cap.
6: Install New Capacitor and, your ready to go.
Make sure you pull out the "Service Disconnect" Breaker Located on the Wall next to the condensing Unit Before you do any work. Replace when you are done..
Hope i Helped
Please Rate Me
Thanks
George
Apr 28, 2009 | Heating & Cooling
New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Nov 29, 2008 | GE JVM1631 Microwave Oven
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
Heating & Cooling Logo
2,604 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
