Question about Toshiba TEC B-SX4 Thermal Label Printer
Display is showing no paper when trying to print - paper is loaded
    Champion:
  • 254 Answers
Check the position of the label sensor:
Check if you are not positionned on the liner.
If this is the case recalibrate the sensor especially the Trans P.E value
P.e is Paper end
Posted on Aug 24, 2011
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
Showing out of paper even though paoer loaded
Nov 10, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hi I have a kyocera C5015Nand it keeps telling me to load MP 4 try can you help please
to get the print press down arrow key it will show use alternative paper ? in display then press two times enter key it will print.............
its is the problem with the document page setting which one you giving print .......... its shows because its asking the paper according the document page setting ..........
Oct 17, 2009 | Kyocera Mita FS 3800 Laser Printer
Will not print
Try to power down the printer (including unplugging it from the wall) then take out the paper trays. From there, reseat the tray guides (so pull them all the way in, then all the way out). From there replace the paper in the tray, and then re-align the guides to the paper. Plug it in, and then try a test print.
Apr 03, 2008 | Lexmark T632 Laser Printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
80 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
