Question about Intermatic EI210 Electronic Auto Shutoff Timers
How to hook up a auto shut off timer - Intermatic EI210 Electronic Auto Shutoff Timers
  • 56 Answers
When you take off the old switch you will have two wires going to it. One is a hot and the other is a switchleg. On your timer you have a red wire which connects to the wire going to your light(switch leg) a black which connects to the hot feed and a white which will connect to the neutral in the box. (If you do not have a neutral this timer will not work) The neutrals will be white wires that are connected together with a wirenut and pushed in the rear of the box.
Posted on Oct 01, 2010
Why won't it drain through the hose?
continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
Aug 13, 2014 | Haier DE45EK DE45EK-L 45 Pints...
I have a 196-036 timer. Stored it inside during the winter. Hooked it up yesterday, everything works, (info panel), but it will not allow water to disribute. Tried manual and auto programing. Any ideas?
Most issues of this sort with these timers is water pressure holding the valve shut. Reduce the flow from the spigot and try again. If the timer still does not operate properly I would suggest removing the timer from your water system and manually activate the valve. Listen for the solenoid to click open, this can be fairly faint so it may take a few tries to definitely tell if it is operating. If the solenoid will not operate it would be best to replace the unit.
Mar 22, 2011 | VIA Garden
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Dryer Shuts off with full load
ok so it runs for the full time set when on timed dry. auto from optimum or less dry runs quickly, correct?
Auto runs on yours by advancing the timer whenever the thermostat is satisfied with the temp coming out. This has a wire that runs from the heater to a resister mounted in the console area then to the timer providing the power to run the timer motor. Most commonly the heater is the cause. GE dryers have 2 elements side by side that operate indepenently but if one goes out the unit will still heat but the circuit for auto is like the heater is off advancing the timer.
the heater is located behind the drum on the wall. first measure the resistance on the resister, i believe 1.4 k ohms see diagram behind it.
to get to heater, remove 2 phillips screws inside door opening top holding top down. then lift top and slide to left if plastic console. to unhook from console. remove 2 screws holding front to cabinet, disconnect wires at bottom left on panel. reach inside on bottom (2 hands may be necessary) pull tensioner arm to right and hook on motor side, it will stay there till pushed. you will get red grease on you. Now you can pull the drum straight out, its a tight fit up front you can remove a side screw to help. you now have an excellent view of the heater. any breaks in either coil?
May 03, 2009 | GE DBXR463EDWW Electric Dryer
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Flat screen tv
Yes that is most likely the problem. But you might also want to check to see if your TV is set up on an auto timer to shut off.
Feb 29, 2008 | Televison & Video
Intermatic EI210 Electronic Auto Shutoff Timers Logo
80 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
