Question about Sewing Machines
When I thread my machine and try to sew, the stitches don't hold or it all gets tangled! The thread won't stay in the needle. And the bobbin angles up sometimes. I'm new to sewing, never have before. I'm trying to alter some clothes and stuff. It works sometimes, but most of the time it won't. I have a HusqvarnaViking Huskstar E10. Any help would be GREATLY appreciated.
  • Sewing Machines Master
  • 7,365 Answers
Check the needle to see if it's damaged-roll on flat surface to see if it roll correctly
always make sure to have a 3-5 inch thread tail for top thread & bobbin
if the bobbin angles up at times, it could be getting low on thread-on my electronic sewing machine it does that
sometime the thread & needle are not compatable
here's how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
sometimes when sewing the thread can get caught different places
1.spool pin
2.notch on spool of thread
let me know if this help you
Posted on Oct 01, 2010
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Bobbin thread is tangling around bobbin carriage as I sew. So I can only go a few stitches before the machine stops sewing and it's tangled.
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Jul 12, 2011 | Singer 4830
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
My needle keeps coming unthreaded. HELP please
1) Open the needle plate and bobbin case and make sure the tangled threads are removed.
2) Open the manual; read and follow every step.
3) Thread the machine with the presser foot up - this is often overlooked and causes loopy stitches that pull right out.
4) Make sure the bobbin in inserted so the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
5) Take hold of the needle thread and lower, then raise the needle to pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
6) When you come to the end of the stitching, make sure the take up lever is at it's highest position. This will keep the thread from coming out of the needle when you begin to sew.
I hope this will help and you will soon be sewing.
Mar 10, 2010 | Sewing Machines
Needle's thread gets tangled in bobbin
First, open the needle plate and make sure the bobbin area is clean and free of lint and thread.
Check the needle to make sure it is not bent and is properly inserted into the holder - usually with the flat side facing to the back of the machine.
Refer to your manual for bobbin insertion to be sure the thread is feeding from the bobbin in the correct direction and through the proper guides.
Always thread a sewing machine with the presser foot up. This opens the tension control and allows the thread to properly enter.
When the foot is down, the tension control closes to the sewing setting and if the thread is not in place, there is no tension on the thread and it gets loopy.
After threading, lower and raise the needle while holding onto the thread tail. This will pull the bobbin thread up through the needle plate. Take hold of both threads and take them under the presser foot and to the back of the machine.
Hand walk the first stitch when sewing and this should keep the top and bottom thread from tangling.
When stopping to change the position of the fabric (turning a corner, sewing a curved seam for example), do so with the needle down into the fabric. This not only anchors the fabric so it does not slip, but prevents mis-stitching.
If you are doing everything according to the manual and are still having a problem, the machine may need to be professionally serviced.
Feb 23, 2010 | Elna 1010
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
