Question about Dell Inspiron 5160 Notebook
External hard drive
Laptop does not recognize my western digital external harddrive "My passport Essential" 160GB. my home PC does recognize drive, so it is in working order. Both computers run on XP. WD could not fix problem and told me it's an USB problem with DELL, Dell refuses to help me unless I pay a 40 dollar technical support fee.
i read that many laptops have problems with not having enough power in the ports. could that be my problem?
  • 2 more comments
  • isassy May 26, 2008
    laptop does not recognize my western digital external harddrive "My passport Essential" 160GB. my home PC does recognize drive, so it is in working order. Both computers run on XP. WD could not fix problem and told me it's an USB problem with DELL, Dell refuses to help me unless I pay a 40 dollar technical support fee.
    I am not sure that this is a problem. I read that a few laptops have that problem, so I was speculating. Does anybody think it could be something else instead?
    I called Dell already, since the drive worked immediately on my home PC (also a Dell). My laptop is not under warranty anymore and a technical support question would cost me 40 Dollars. It's not about the money but I would like to pay that and know they can actually help me. Not a big Dell fan anymore, so my trust in them is shot. I have two slots in the back of my laptop, we bought a thing that plugs into the side of my laptop and it provides me four additional slots. Some of them recognize the drive but still refuse to install because it's looking for a CD or software (the drive doesn't come with either) and the ones in the back both recognize it but give me the same installation problem.
  • will_chase Nov 18, 2008
    Western Digital My Book external hard drive, 400 gb Essential Edition.
    I have two Dell desk top computers one with Vista Home Edition and one with Windows XP Pro. I can not get my External Hard Drive to work on either one. It was working on one when it had Windows XP home edition.
    Now I have updated to XP Pro and it stopped working.
    A widow pops up stating that it discovered new hardware and is searching for a way to install the programs to run it. Then it ends up telling me to insert the software or notify the provider to download the necessary software. Of course Western Digital will not allow me to download the drivers because I bought the hard drive over one year ago. Is there any other way to extract the drives and/or software for the external hard drive itself? I was thinking that if that were possible, then I could burn them on a CD and just install them myself..
There is no enough power in you USB port. I was have similar problem with my old PC (Duron 1.3GHz, I don't know what motherboard).
When I conected HDD (My passport Essential) to USB (there is only USB 1.1 port on this MB, and probably if you have USB 2.0 you will have no problem), hardware wizard is started, looking for drivers (which are not needed to install portable HDD), and then I have message like "unrecognized USB device ...".
SOLUTION: On this MB there is 6 USB 1.1 ports, but only 2 are connected on case (with plugs on case outside), others are on MB and if you have cable you can use it. In my BIOS all 6 were turned on, and I think there must be a problem with power on chip (you have some power divided with 6 ports, and this is not enough for HDD).
I turned off my other USB ports in BIOS, and left only fist two, and HDD is now in my computer ....
Posted on Nov 10, 2008
    Scholar:
  • 110 Answers
If you believe that it could be that, get an external, powered USB hub with a mains adapter. That might add enough power to the ports to allow the drive to run.
Posted on May 26, 2008
  • Edward Sheldon
    Edward Sheldon May 26, 2008
    I haven't met the problem where a modern day laptop has any difficulties with power. Many modern day laptops have between two and four USB2 ports which can directly use any USB device currently on the market, so I can't see how the fault would be in the laptop unless there was actually a motherboard issue. Certainly hard drives are very low on energy consumption because most have their own power adapters. If for some reason your laptop can't use it, try plugging it into another PC. If that has no problems then tell Dell there is a problem that requires a warranty repair, and they shouldn't charge you.
  • Edward Sheldon
    There should be no drivers under XP or Vista for any hard drive or USB key - it installs as a "mass storage device" which is a very basic device and fully natively supported by the operating system. It can clearly see the device, but for some reason it's not reading the correct "class" or ID for the device as a hard drive. This is most likely not down to power.
    As the motherboard on the machine controls all the USB ports, if it's the controller chip on the motherboard all the USB ports are going to have the problem. The only way to prove beyond all doubt would be to use a PCMCIA card with USB ports built in, but that's going to cost more than Dell want to charge. To my mind, there is no actual technical solution to this, it's most definitely from what you've said a hardware problem, and quite likely on the motherboard of the laptop.
    If it's out of warranty then you are going to have to weigh up the pros and cons of getting it repaired. Approach Dell not for technical support, but for a repair quotation for replacing the motherboard and see what they come up with. From that you can decide whether or not it's viable to repair, or whether you could get some money back selling the machine sold-as-seen on Ebay or through the local paper (remember to let the buyer know that there are problems, and what your suspicions are) and put the money you raise towards a new laptop.
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
Problems with my passport harddrive
Corruption or failing/failed drive. Mac supports
HFS+ (mac filesystem)
NFTS and FAT32 (windows filesystem)
exts2 (linux/unix)
Dec 16, 2012 | Western Digital My Passport Essential...
PC will not recognize the external harddrive passport. PC has been rebooted and passport has been unplugged and replugged to get PC to try and recognize passport. Light on the passport comes on, and the...
3 beeps its searching for a connected device
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 13, 2011 | Western Digital 1TB My Passport Essential...
My computer wont recognize the drive or allow me to reformat my passport.
Try downloading the device driver from western digital site for your respective OS. And try formatting it with the western digital inbuilt software, which works great.
Jun 30, 2010 | Western Digital My Passport Essential...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
USB ports on my laptop and others wont recognize my 320GB Passpor
we have to check in BIOS weather the "USB EMULATION" option is enabled or disabled.also if you have usb 1.0 and not usb 2.0 this external hdd will not be recognised.
Apr 24, 2009 | Western Digital Passport 320GB External...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
Western digital passport essential harddrive 250 gig
It assumes that the drive C is the drive you booted from or the "root" drive. You must make it something other than "C". Try putting in a camera card, hooking up an external drive or other device that the computer makes drive "C" THEN hook up your passport. It will be "D" or "G" or something other than "C" and it will work.
Oct 24, 2008 | Western Digital Passport WDXML800UE...
Dell Inspiron 5160 Notebook Logo
408 people viewed this question
Alun Cox
