Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Color problem The red light seems to be Orange not red and everything on the picture that is red is more yellow than any other color. Any ideas?
  • 927 Answers
Good Day, pmusso:
The lamp may be going bad/weak.
You can replce it yourself it's easy; call mit's they send to your home with detailed instructions.
Good Luck, big IRISH.
Posted on Aug 13, 2008
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
Apr 13, 2010 | Car Audio & Video
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Mar 29, 2009 | 1994 Ford Explorer Limited
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Component color turns yellow
when you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Jul 01, 2006 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
