Screen Doesn't Appear, power comes on but NO Picture,pls help
    Problem Solver:
  • 5 Answers
There are several possibilities that come to my mind about this problem.
Firstly, most problems come down to power, or rather a lack of - because of a component breakdown.
1]...It may sound obvious, but there could be a problem with the unit's internal power supply module that regulates the supply to the HT (High Tension) side of the circuit; It could be
a]...a transistor;
b]...diode;
c]...safety resistor;
d]...Or, but unlikely, a fuse.
this is the part of the main board that contains the line output transistors, line output transformer (LOPT) etc, & supplies the extremely high voltage (typically thousands of volts) to the crt (Cathode Ray Tube).
2]...It could be the line output transistor, or another component - such as a safety resistor - in the line out stage.
The line output transistor would be located on the heatsink, very close to the LOPT.
3]...It could also be the line output transformer;
a]...My first check for this would be for dry solder joints on the LOPT, on the underside of the main board.
I must stress, as a retired tv engineer myself, there are very dangerous voltages inside television sets, & I talk from experience - I've had some nasty shocks in my time, & it only takes a few milliamps of current to kill you, if it goes through your chest (Up one arm & down the other).
Even after a tv has been unplugged from the power socket, on the wall, it can contain dangerously high & possibly fatal voltages.
So please, DO NOT attempt this repair yourself, unless you are qualified to do so; either ask someone who you know, who is qualified, or take it to the tv repair shop.
I hope this has been of help to you.
Thanks,
Steve.
Posted on Oct 01, 2010
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
When I click the button to take a picture the screen goes blank and doesn't come back on. Power light is still on.
Your shutter is stuck open. Remove the lens. Set to fireworks mode. May need to be in a dark room. When you press the shutter button tap the camera with an object that won't damage it. I used a rubber coated knife handle. Pull the battery and repeat. Tapping all around the camera. Hopefully it will break free. Then do some continuous shooting to loosen it up.
Nov 27, 2011 | Olympus PEN EPL1 Digital Camera
I turned on my labtop after repalcing the power inverter and the screen is still dark
Hi brylindo.
Try hooking your laptop to an external monitor...if the picture comes on then it is an lcd screen problem...if it doesn't come on then re-down load your drivers and see if that solves the problem...if it still doesn't work then you may have a problem with the laptop electronics.
Please take time to rate me
Sep 13, 2011 | Toshiba Satellite P105-S6197 Laptop
Cant load channel sound but no picture
First reset it to factory default: While pressing [VOLUME ( - )] button on the TV, press [MENU] button of the remote control 2 seconds, the self check screen will appear, then Unplug Power to reset.
If doesn’t work, update the software, if still not work, let me know.
May 31, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Screen goes off after every 2 secs. Pls help
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Sony VAIO VGN-N130G/W Notebook
Picture ok through viewfinder but after picture has been taken horizontal bars appear on screen and final picture
CCD FAILURE !
just call FUJI in ur area they will do it free of charge even if u are out of warranty dont worry it is a known problem thousands are facing these days just call them and everything will be ok PLS RATE ME FIXYA for help
for support www.fujifilm.com
see this
http://www.imaging-resource.com/badccds.html
Apr 14, 2009 | Fujitsu Cameras
? hardware problem?
First , u have to check if theres any usb device connected to your USB port, or any cd on your ATAPI Drive (S)....remove those usb and cd....
restart the PC and press " F8" after the BIOS screen appear, then select "last configuration that worked" then press enter....
Dec 30, 2008 | Acer Aspire 5920-6727 Notebook
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
HP Pavilion - the monitor flashes off and on
Pls uninstall the video card drivers and reinstall them.
Also pls look for any graphics driver updates from the manufacturer.
Also pls check if the cable from the power supply for the graphics is connected on the motherboard.
Pls check with another monitor if it is doing the same thing.
If the same happens with another monitor, then it is an issue with the video card..
Jan 14, 2008 | Computers & Internet
Date doesn`t appear on the photo in computer
Download the userguide from the following link and please refer page 74 & 75 http://esupport.sony.com/perl/model-documents.pl?mdl=DSCW50 Good Luck
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
