Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
How to install a/c capacitor
By scoot50 on May 26, 2008
How do you install a replacement capacitor ? Thanks.
Comments:
May 26, 2008
- It is a GE window air conditioner Model # AGD14AAG1 and we need to install a replacement capacitor. How do you install the replacement capacitor ?
Best Solution
posted on May 26, 2008
Very Helpful)
robotek
Rank: Guru
Rating: 91%, 1168 votes
hi scoot
Is a simple procedure, just change the existing capcitor for a new one. Do you have the old one still fitted to the unit? I will be able to steer you through it
regards
robotek
Comments:
May 26, 2008
- The capcitor is a cylindical shaped device that fires up the start circuit pof your A/C. have you got the covers off yet. FIRST be sure to disconnect fully from the power supply. If you do not have a circuit breaker next to the unit, then you will need to isolate it from the mains powwer supply. You will need to remove it from the window.
May 26, 2008
- Air Conditioner Capacitors
There are two critical specifications that need to be identified when looking to replace an air conditioner's fan or compressor run capacitor, the voltage and the capacitance rating in microfarad (uF or MFD). The physical size and shape (round/cylindrical or oval) is irrelevant except for mounting considerations and you will often find newer capacitors considerably smaller then old ones of the same rating.
As a replacement you can use an alternative of a higher voltage rating without any problems but the capacitance should be within 10 percent of the original but an exact replacement is always best.
Some models may utilize a 'dual' capacitor where the compressor and fan motor capacitor are built into one. On this type you will see 3 groups of terminals across the top of it. There will be one set of common terminals, one group for the fan motor and another for the compressor wiring.
The common terminals on a dual capacitor will usually be indicated with the letter "C" near the associated terminal set, the fan side may or may not be indicated. The compressor will almost always be indicated with the word "herm" (short for hermetic) indicating part of a hermetically seal system (which the compressor is part of).
Dual capacitors are usually considerably more expensive to replace than single purpose ones.
May 26, 2008
- I searched for a service manual for you to make the job easy, but did not find much of anything unfortunatly. I was able to locate a source for the part you need. :)
You can purchase the part you need online from here
The part is not hard to change, as it mounts with a clamp, and has some wires connected to it. They just need to be replaced to the new part as removed from the old one. If you need more advice, or just a confidence boost.. :)
I am here to help, just let me know.
Thanks for using FixYa
regards
robotek
Rating Locked! (?) scoot50 has rated this solution as Very Helpful
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
the power board was damage ,got anew one but dont know how to rewire it back
Answer
my kenmore ac got a new power board but I dont know how to rewire model 580.72056200,could you sent... (More)
Answer
carrier split a/c made in egypt model 38qg24-h 24000 btu
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
