Question about LG LFX25960ST Stainless Steel French Door Refrigerator
The flapper on the ice dispenser opens but won't close. I'm thinking that the flapper needs to be changed. Before I get parts, I would like to take it apart and make sure I don't need something else. How do I take this apart (from the inside of the icemaker or from the outside)? I gently pried loose the frame on the outside but the shoot doesn't allow me to remove the front pieces. I'm thinking that I need to approach it from the inside at the icemaker......
fridgetech
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Posted on Oct 21, 2007
SOURCE: lg lfx25960 Ice Dispenser
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Posted on Feb 09, 2008
  • 210 Answers
SOURCE: LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Posted on Jun 02, 2008
SOURCE: Maytag MFI2568AEB- icemaker flapper keeps
talked to a buddy of mine. sensor in behind the control panel is out. not the flapper. also contorl panel might be out.!
Posted on Aug 07, 2008
ginko
  • 19396 Answers
SOURCE: Kitchenaid KSRS251
If you post exact model number here you get exploded view. Alternatively give us model number.
Posted on Aug 09, 2008
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
APPLIANCE 911
Apr 27, 2016 | Refrigerators
Why are my ice cubes dispensing faster than my crushed ice. I changed the auger assembly and crush ice is still slow coming out of dispenser.
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
I have gone on many a service call in regards to this issue. People like their crushed ice.
The auger was not the problem. It is the nature of the beast.
Regular ice cubes have more density (Heavy) and exit through the door dispenser with no problem.
With crushed ice, shaved chips they are lite. When you dispense crushed ice the ambient room temperature (warm air) creates condensate and bines the crushed ice together. Fragments of the crushed ice block the dispenser flapper from closing all the way. The flapper remains a little bit open and ices up.
The manufacturers recommend after you run crushed ice that you run cubes through your dispenser to clear the crushed ice fragments.
Well, that solution is from engineers sitting in a office.
The solution is, from a old experienced field technician is: Reach up and wipe the flapper with a dry cloth. Look up and make sure the flapper is completely closed.
If you need a tech call me at 414-306-1362. Glen Burnie, Maryland, USA
Dec 30, 2014 | Refrigerators
Flap for ice dispenser won't close
ok you have to replaced the flapper (door recess asm) here is the part no. WR17X3093 makle sure to defrost all ice or snow around the flapper and replace it with the new one
Aug 04, 2011 | Hotpoint HSS25GFP Side by Side...
I have the model ED5VHEXVQ Whirlpool side by side refrigerator and the ice dispenser flapper will not close all the way after dispensing ice which causes the build up of ice crystals inside the door. This...
Hello, Thank You for using FixYa. I will be helping you today.Alot of times the plastic clip breaks that holds the pin and spring for the flapper door the only way to fix it is install part 8201756 and it comes with directions.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE SS25ksta side by side refriderator. The ice maker makes ice, but the chute jams without fail. It is almost as if the ice doesn't weigh enough to push open the flapper arm at the bottom of the...
there's a solenoid that opens and closes the shute or the flapper.the part number is WR62X10055 and it's around 25 dollars.check around the plastic frame that holds this section of the dispenser in place,i'm pretty sure the frame pops off,you might need a putty knife or thin screw driver to pop it off,then you can get at the rest of the parts to change out the solenoid.it's self explanatory and easy to change it out once you pop off the outside frame piece
Jan 16, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
Apr 14, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Kenmore side by side icemaker
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
98 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
