Question about Roland Spd-S Sampling Percussion Pad System
Pad sound not geting
I have SPD-S pad one pad of them is not getting sound what's the problem?
  • e76t Oct 28, 2008
    Two pads went out on me.
  • Anonymous Nov 21, 2008
    I have roland spd11 the  left botom patch comes out three difirent sound,so what should i do?
    New Friend:
The pads dont spoil easly... just check the solder ... may be there is a problem in your main board.. remove the battery and the power and leave it over night.. next day put back the battery and try.... mine works very well but only for 10 seconds.. then the volume goes very very low.
Posted on Aug 26, 2014
The trigger may have gone bad - I'm actually on line now looking for replacement parts.
open up the unit and that part looks like a coin, attached to a wire.
Posted on Sep 11, 2008
  • prakash Rodrigues
    prakash Rodrigues Aug 26, 2014
    the pads dont spoil easly... just check the solder ... may be there is a problem in your main board.. remove the battery and the power and leave it over night.. next day put back the battery and try.... mine works very well but only for 10 seconds.. then the volume goes very very low.
Editing Problems
You have Pad Chase turned off. Turn it back on.
Mar 11, 2012 | Roland Spd-S Sampling Percussion Pad...
Display on Spd-S
this could be fixed at a cost of nearly 100$
Jun 13, 2008 | Roland Spd-S Sampling Percussion Pad...
My spd20 pad skin is damaged so i want get a new skin ???
Hi.
You need to order the pads skins directly from Roland.
The local Roland number is written in user manual.
Here the service locator in US. If you are based in the USA you can also order the skins from your local authorized Roland Service point.
Here Roland US support contact.
In UK see:
Oct 25, 2010 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-s pads not working
Check for a cracked PCB internally from the two defective pads, or if the wires have detached from the trigger. You may not need parts, but if you do, it really depends on how helpful the Roland distributor in your area is as to whether you will have any luck getting them, or you may have to go trough a local authorized repair shop.
Good luck.
Dec 01, 2009 | Roland Spd-S Sampling Percussion Pad...
Removing files
Hold down the "Wave" and "Setup" buttons at the same time while powering on the SPD-S. This will turn off the protection; you should now be able to remove the file.
To turn the protection back on, perform the same procedure again.
May 24, 2009 | Roland Spd-S Sampling Percussion Pad...
SPD-S.....Internal Memory Full
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing.
In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
Dec 31, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-s pad #1 change to different patches when hit
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
Aug 08, 2008 | Roland Spd-S Sampling Percussion Pad...
File import
Try IMPORT instead of just trying to load them on your SPD-S.
The SPD-S uses some kind of its own file-format.
Regards
May 18, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-S Sampling Percussion Pad System Logo
244 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
