Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I am allways getting a "OL" on the display after an initial cycle start.
  • kurtohler Oct 01, 2010
    Thank You for your response, I made a mistake when I posted the problem. My unit is actually a WTW6400SW, and it gives the "OL" at the end of each cycle.
    I dont know if this makes a difference.
    Would you have a part number for the spring kit that I need to fix the problem?
    ALSO just today I am Getting an "F1" fault.
    I read that it could be an issue with the air system???
    Do you have instructions on how to check this?
    Thank You
    Very helpfull, and fast response. I will use them again.
  • 10,515 Answers
The problem is with the suspension springs which weaken over time. The rods and springs are easy to replace once you hinge the machines top up and back. You won't believe the "springy" difference, or lack thereof, between the old "sprung" springs and the new ones. Additionally, the new set includes plastic cups, in lieu of grease, which go on top of the frame to cradle the new rod caps.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2010
  • taran_2005
    taran_2005 Oct 01, 2010
    Thanks for your response!!
    Yes, the solution would remain the same for all Whirlpool washer's.
    F1 means the main controller has failed. The cost of the part is around $175.00 from Sears BUT, many revisions of this
    machine were recalled due to this problem so you may be able to get the
    board for free. Please call Whirlpool first and give them your serial
    number to see if your machine is covered under the recall. If not, they
    still MAY send you the board for free and you can install it yourself.
    Its very easy and I can help with that if it comes to you having to fix
    it yourself. unfortunately, there is no other fix for this. You can try
    unplugging but you already did that so you will need to replace this
    board.
    Hope i helped you.
OL before spin cycle starts
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
The washer stops half way through all cycles and displays "oL" .
Error oL means overload.
If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
*Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
*Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
If Pause/Cancel does not work:
*Unplug washer or disconnect power for one minute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Hope this helps.. :)
Jun 08, 2011 | Washing Machines
OL displayed during wash cycle
oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.
Open the door lid to clear display, remove excess laundry, then restart the cycle.
Jan 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
We have a newer Whirlpool Cabrio washer and no matter how many clothes we put into it we always get a ol error.
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does it mean when the machine gives an oL sign when starting the wash cycle?is it a quick fix and how much will it cost? It is a top load whirlpool cabrio washer.
Hi
Thanks for using FixYa. Error oL means overloaded and it flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. To clear this error you’ll have to open the door lid to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine on the display has a oL. Can you help me?
HI. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle. This will correct the issue.
  • NOTE_Be sure to only fill the unit to specifications. Do not overfill the unit. This will damage your motor.
Aug 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Keep getting the overload message "OL"
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controler board is damaged and will need to be replaced.
Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Sep 05, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
656 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
