Question about Epson Stylus Photo R220 InkJet Printer
Reg epson r220 printer
My printer stop working, the power light is off and the ink and paper lights are flashing and this the message that appears on the screen (Parts inside your printer are at the end of their service life.
  • 159 Answers
Had the same problem. (this works great) fixed mine.
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty. Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
  • Bill Miller
    Bill Miller Feb 14, 2009
    Do this 1st. sorry forgot this step.
    this is how to reset it try it 1st.
    • ress and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen
      saying counter is reset and to turn the printer off. The R200 and
      others don’t have a screen so just wait until the 10 seconds is up.
    • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
3 Suggested Answers
  • 691 Answers
SOURCE: Epson Stylus Photo R220 InkJet Problem
The erroris an ink overflow protection error and is fairly easy to rectify. Youneed to clean the waste ink pads in the bottom of the printer and thenuse some software to reset the internal counter. You can download allthis stuff from the link below:
A waste ink tank, does not stop the ink counter incrementing each timeink is used. All it will save you is the time taken to replacethe ink pads - which you can wash out and reuse anyway.
Posted on Nov 10, 2008
  • 95 Answers
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website for the inkpad reset utility
Posted on Sep 10, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R200 lights flashing but printer not being picked up
Please ensure that there is no paper jam in the printer or any door open thereby. Replug the printer after 10 min. powering off.
First start PC and then printer. Report us back for further assistance.
Aug 27, 2009 | Epson Stylus Photo R220 InkJet Printer
I need to clear the inkjet heads on my Epson Stylus R220.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off. Access the printer software. Click the Maintenance tab, then click the Head Cleaning button. Follow the on-screen instructions. The power light flashes while the printer performs the cleaning cycle. Never turn off the printer while the power light is flashing. Doing so may damage the printer. When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Apr 21, 2009 | Epson Stylus Photo R220 InkJet Printer
this sounds like ur both cartridges are empty...
Jul 28, 2008 | Epson Stylus 880 InkJet Color Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
This is probably due to the waste ink pads needing replacement. If you still have this problem and would like help solving it, please post a new comment to this effect.
Mar 19, 2008 | Epson Stylus C62 InkJet Printer
google the software for epson that resets the counter of the printer. I think the name is SSC.... just think of the appropriate search criteria like "reset epson"
Mar 19, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Red Flashing lights
hi dear
try to resetting your catridge
or here
i hope your problem clear
good luck
Mar 19, 2008 | Epson Stylus Photo R220 InkJet Printer
i have a R220 it says it needs a service can you help
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
