Question about Fisher and Paykel DEGX2 Dryer
I have a F&P DEGX2 dryer and it is is not making any heat. There are no trouble codes in the recent fault list. There is plenty of airfloe and the dryer will continue to spin and the progress light remains on drying. Any ideas?
  • Fisher and P... Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heatingcoil,sometimes the coil is located at the front just under the door of the machine or sometimes in the back of the machine.
Also try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Posted on Oct 01, 2010
Testimonial: "I took the machine apart and checked all of the t-stats with an ohm meter, and they were all ok. I cleaned out all of the lint and it works fine."
  • efay23 Feb 20, 2011
    We have this problem with ours. Here what you do:
    Unplug the dryer and open the lid. There are two caps on the sides toward the front. Take a flat head screw driver and GENTLY pry them off. Underneath are screws. Take out the screws and then top will come off. Be careful, there are still wires in the back keeping it attached but you should be able to move it up and back just enough to see the top of the front panel.
    At the top of the front panel, there is a screw in each corner (two total). Take those out. Then, removed the front panel. This will take some wiggling and you'll have to look at how it goes together first because it doesn't just slide off. There are pieces from the side panels that fit into the front panel so look at how they fit together.
    Once you have the front panel removed, there is a small red button at the bottom of the barrel. Press it and it will make a small click. And that is it. The problem should be fixed. Apparently, this is VERY common with this dryer. A very common very sucky problem because it will probably happen again. I just reset ours TWICE today. Good luck.
Lint will not go into lint trap
Posted on Jul 07, 2011
I started the test cycle to make sure it works properly and in the middle of the test a code of D80 appears and a little smoke witch is not good. Does anyone know what this code means?
Digital control washers and dryers usually have a list of common trouble codes listed in the owners manual under, "trouble codes". Unfortunately, mostly simple codes are listed. My guess would be to check the thermister, & thermal protection fuse but you can get model specific advice in the trouble shooting section at repairclinic.com. Good luck. Try this link: http://www.repairclinic.com/RepairHelp/Appliance-Repair-Help-Lawn-Mower-Repair-Help-Small-Engine-Repair-Help
Sep 04, 2015 | Dryers
F24 fault code
I dont know about F24 but the book lists normal codes. Trouble is there are other codes as well.
On another make I recently encountered an unlisted fault code. I had a good laugh with the manufacturer when it was listed on the latest documents as "other faults" !
By aware that there are three common faults on your model which could be present in single or multiple combinations.
1. Diverter sometimes fails to move, can give heating instead of hot water.
2. APS sometimes fails to operate and boiler may not fire up.
3. Hot water heat exchanger may be partially blocked by dirt from a system that has not been properly treated.
Feb 24, 2014 | Kenmore HE5 7.0 cu. ft. Super Capacity...
Wont dry dosenot get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[][]
Aug 06, 2011 | Fisher and Paykel DEGX2 Dryer
My degx2 will not dry clothes. there is no heat.
heatman101
';l;'' ;
May 05, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Dryer will not heat
heatman101
Mar 29, 2011 | Fisher and Paykel DEGX2 Dryer
Everything works fine but, no heat
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 30, 2010 | Fisher and Paykel DEGX2 Dryer
My dryers isn't heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 18, 2010 | Fisher and Paykel DEGX2 Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher and Paykel DEGX2 Dryer Logo
500 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
