Question about Toshiba REGZA 52RV530U LCD TV
I have a toshiba model #52RV530U that I purchased a little over a year ago and have what might be described as vertical banding on the 1/2 of the screen on the right side. I have read in the reviews that this is a common problem with these TV's and the people that have had these problems have not gotten anywhere with Toshiba on assistance with this. Unfortunately, as the extended warranty was 1/2 of the price of the television, I did not purchase it. What part is causing this problem and is there any suggestions on my next step?
  • xlauto Oct 01, 2010
    Just to verify. My television is a Canadian model. Before I order this part, is the T-con board the same in US and Canadian models. Talking to the Part store rep, this part # is not available in Canada. If it is the same, thanks for the information, I assumed it would cost me more than what the TV was worth based on the consumer report blog postings.
    Thank you for your information, you were very helpful.
  • Toshiba Master
  • 11,800 Answers
This is caused by the failure of the T-Con board - the board that transforms the instruction data coming from the image processor in the actual commands for the pixels in the LCD panel.
This board must be replaced. You can buy it from here
http://www.partstore.com/Part/Toshiba/Toshiba/52RV530U/Toshiba/Toshiba/75014321/New.aspx
Posted on Oct 01, 2010
  • Azrael SRL Oct 01, 2010
    Yes, it's the exact same part. But the T-Con board should be installed by a pro, who must verify that no other part was damaged when that board failed - especially the mainboard, with the processor. If you do it yourself you have about one in four chances to discover that something else is also damaged. In that case you will need to replace the mainboard, and then definitely will be more than the tv is worth.
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
We have a purple vertical line about half down the screen sometimes it works fine for a little while when we turn it on and about ahalf hour later it goes back to a purple streak
Was the TV manufactured in 2008? What is the model?
I have a failing LCD panel and am starting a class action lawasuit against Toshiba becuase there is a high number of failing units built during this time that Toshiba is not addressing and their customers are not being herd... well I am going to make them listen!
let me know if you want to be part of this activity.
andedwar@cisco.com
Dec 30, 2010 | Toshiba REGZA 52RV530U LCD TV
The right half of the screen developes vertical lines after the tv is on for an hour
What year was the TV manufactured? What model is it?
If its manufactured in 2008 get back with me.
andedwar@cisco.com
Dec 24, 2010 | Toshiba REGZA 52RV530U LCD TV
I have a Toshiba Regza 52RV530U HDTV and it now shows an 18" verticle black bar down the left side of the screen. LVDS cable and Main Board need to be replaced. How much should this cost to...
Curious too, did you fix the TV?
andedwar@cisco.com
Nov 11, 2010 | Toshiba REGZA 52RV530U LCD TV
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Sep 22, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba REGZA 52RV530U LCD TV Logo
932 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
