Question about Consew 226R2 Sewing Machine
What is the wiring diagram from the on/off switch to the motor
Need wire diagram for foot peddle and motor and light on a dressmaker model 2402
I wasn't able get one for you. I have drawn a schematic of how they are connected. The picture isn't exactly art work but it should get you by.
Jul 22, 2015 | Sewing Machines
I need a wire diagram for my bernina 830, please help I am out of commission until 8 get this back together! ! I have the original machine manual but that doesn't go into the wiring of course! I had to...
You will have to deal with this site being in German but it's not difficult to get to grips with. The site is a bit randomly disorganised (much better than it used to be). You'll find lots of other information scattered about the site.
Try the following links:
S21 Elektrik 1 Herzogenbuchsee Info BERNINA Service Tipps Lenco Switzerland
S22 Motor Service Herzogenbuchsee Info BERNINA Service Tipps Lenco...
and here:
830 Record Serie Herzogenbuchsee Info BERNINA Service Tipps Lenco...
I hope this all helps.
Mar 17, 2015 | Brother Sewing Machines
I have a bernina record 830 and i want instructions to install motor on it
You ought to look at the link below. The site is in German but contains loads of information on the linked page and also elsewhere. German isn't insurmountable as a problem these days with all those translation facilities.
Feb 03, 2015 | Bernina Sewing Machines
Necchi supernova julia power problem
sounds like a sew-tric plug an motor if so under the motor's electrical connection cover there is a wiring diagram moulded onto it
Feb 24, 2014 | Necchi Sewing Machines
Motor capacitor wiring diagram
You can do away with the capacitor it is not needed these days
Oct 04, 2013 | Sewing Machines
201-2 singer sewing machine plug wireing diagram
Any of the older Singer manuals will give you this info...here's a PDF for your machine...
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-model-201-sewing-machine-manual.pdf
If that doesn't help scroll down on this page there's a simple diagram on there.
http://blog.sew-classic.com/2009/11/30/replacing-the-wires-on-a-singer-button-foot-motor-control.aspx
Aug 31, 2012 | Singer Sewing Machines
Wiring diagram for Pfaff 30 motor and foot pedal
Request the wiring diagram from Pfaff.
May 12, 2012 | Sewing Machines
Need to know were purple brown and yellow wire off cumbustion motor hook back up to compasetor and circuit board on a carrier 48gs 03609 0301
take off the door panel and look to the inside. It will have a wiring diagram, legend, and color codes for the wires. The combustion motor or inducer fan should be small enough that it doesnt need a capacitor. The indoor fan motor or squirrel cage does.
Nov 26, 2009 | Sewing Machines
White euroflair 8910 motor won't turn on
motor inside the casing you have to remove the cover motor at the rear beside the handwheel of sewing machine loosen set screw or lift upside machine bed so you can see the motor and wiring circuit,if bottom cover is present loosen bolt remove cover you can check motor wiring using multitester setting to R10 set switch on and setting test probe red and black rod attaching the two terminal of male plug start pedal switch besure it was unplug on ac source if there resistance on the circuit and the motor.If negative result.Isolate checking the electrical circuit.check continuity of switch,if ok.check armature winding of the motor in two terminal of the motor, you have to pull out motor inside the casing first remove belt from the motor and handwheel.Loosen the 3 bolt from motor holder to the casing.In motor assymble unlock and pull out two carbon brush attaching tha armature brush replaced a new one pair of carbob brush and install back again.besure winding was not
burn out otherwise you to replaced the motor.
Mar 07, 2009 | Sewing Machines
Consew 226R2 Sewing Machine Logo
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
