Question about Eureka 4472 Vacuum
How do I unclog the hose on eureka model 4472?
  • 490 Answers
There are a couple ways (more, I'm sure). Disconnect the hose from the vacuum and invert over a waste receptacle while stretching it and straightening it simultaneously. By stretching and shaking it, you can dislodge all but the most stubborn clogs. If that fails, straighten a portion of wire clothes hanger and bend a small hook in the end. Using your new tool, fish out the clog in bits until clear. Use care so as not to puncture the hose with the hook. Farmerbear at FixYa.com
Posted on Oct 01, 2010
Nothing is going into the waste basket when i vacuume
Do you mean the "bag"? If so you have a clog. The first thing is to check is the on board tool hose. Remove the hose from the machine and check suction at the end of the hose. If you have no suction there the clog is between the end of the hose and the bag. Open the bag door and remove the bag. You will have to use a coat hanger wire, make a small turn at one and slowly put it though hose to unclog. If you have suction there, check the section of hose between there and the head of the vacuum with coat hanger wire. If nothing there, then remove the base plate and check the inlet for the dirt there. You should also check to make sure the belt still turns the brush roller, if not replace it.
Apr 27, 2010 | Eureka 4467AV Upright Vacuum
The hand held hose is clogged at the very bottom how do I unclog it
Disconnect the hose and run a stiff wire or dowel in and out of it.
Mar 27, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima (yellow)
the hose under your dusting tool, remove that and you should see the clog. i had the same issue and also found that the smell that is emitted went away after i unclogged it
Aug 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
CHANDE BELT
you can find out how to change the belt in the manual here that I included on page 4.
http://www.eureka.com/servlet/FindOwnersGuide
Good Luck And Please Rate FixYa!
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
No dirt is getting to the plastic container.....
if the filters are clean I doubt it! Under the foot of the hoover there should be a little black cover/flap that covers the intake part of the hose, try lifting this flap forward and see if there is any blockage at this end.
Oct 26, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka 12 amp vaccum lost all suction how do I fix this?
There must be a clog somewhere in the line. I don't know this model, but if it has a hose, disconnect it and see if the machine has suction. If yes, then you know hose is clogged. If you don't hace hose, then you can try to take apart the air intake to unclog it. It is also possible that the motor runs, but the impeller on the motor is loose and is not spinning to create the suction. I would try checking and cleaning any clog first. Good luck!
Feb 28, 2008 | Vacuums
Eureka 4472 Vacuum Logo
78 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
