Question about Radio Communications
Uniden bearcat bc700a
The front buttons dont work nor does the main display but if you turn the power on it just makes stattic please help thanks in advance
  • Anonymous Mar 20, 2014
    turned on says memo losss
Try a total reset your backup battery died
Posted on Aug 05, 2008
Uniden bearcat scanner 800 xlt comes on but screen will not display
This may require return to Uniden for replacement of the screen
Oct 28, 2012 | Uniden Radio Communications
Manual for Uniden Bearcat Scanner BC120XLT
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Uniden BC370CRS Base Scanner
Uniden BC700A, has been in storeage for a few years now when pluged in will not turn on.
Remove Batteries if fitted unplug from mains power point. Buy a spray can of electrical contact cleaner,CRC or equivalent.
This spray can be bought from radio shack ,Tandy or siiliar stores.
Unscrew cover of scanner and spray a little on the "on/off" switch,and toggle switch on and off while unit is isolated from mains power and battery power.
If your unsure how to remove cover ,spray a little directly on outside of switch and toggle on and off .
wipe off excess spray and try to power up again.
Hope this helps.
Sep 13, 2010 | Radio Communications
Need help to repair 780 XLT Uniden..Scanner..
You can try a system reset (press and hold 2,9, and MANUAL while powering up), but chances are that the display is shot. You can try a local repair shop if you have one that you trust, but I recommend contacting the service folks at Uniden.com for a price quote on repairs.
Dec 26, 2009 | Radio Communications
How do you program in the frequency
There is no programming on this radio. With power and an antenna connected, turn the power on and you should see a channel number in the display. Turn the volume up about 1/4 of the way, and turn the squelch down. You should hear either transmissions or noise. If all you get is silence, the receiver section is "fried." If the unit does not power up at all (no lights/displays at all) then you most likely have a blown fuse - a simple fix.
Jun 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
NEED HELP
try the power button, make sure the battery switch is set to your type of batteries
Mar 13, 2009 | Uniden Radio Communications
Lost book to scanner its a uniden bearcat bc145xl 16 channel and dont know how to program it.please help
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Jan 13, 2009 | Radio Communications
Programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Feb 11, 2008 | Uniden BC248CLT Base Scanner
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
Jan 24, 2008 | Uniden TRUNKTRACKER III
Radio Communications Logo
716 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
