Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Dryer just hums when i start--tub does not turn.
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
This is a FREE answer, Please rate me
Posted on Oct 01, 2010
I have a samsung DV2C6BEW/XAA that turns on and when you press start just sits there and hums ive already checked to see if the belt was attached and it looks good... Any other suggestions?
Try turning the motor or with the picture you have can you start the dryer and observe the motor? It may be the motor humming and not turning. this could be a bad motor, something stuck in the blower wheel or the tub binding somewhere.
May 27, 2015 | Samsung Dryers
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
Dryer will turn on but the tub will not turn just hums
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Electrolux Dryers
Dryer won't start. has power, lights are on, when I push start I just get a loud humming sound.
Try to turn the tub by hand, if it will not move or is real hard to turn, your motor may be locked down. They usually make a humming sound when you try to start.
Aug 28, 2010 | GE DPSB513BW Dryer
Turn on it only hums
most likely a bad motor or something stopping the motor like a missing sock or cloth jammed into blower area..open door and spin tub while holding in door switch. a second person may be needed to turn on dryer at panel. if tub starts while turning tub by hand. you'll need a new motor. if still does not start..check for obstruction..no obstruction, bad motor
May 15, 2010 | Dryers
Whirlpool electric dryer tub won't turn. Belt is
if you are hearing loud buzzing or loud humming when start switch is engaged,u have 2 possibilities:1. a bad motor. 2.something hindering the motor's ability to turn.most likely cause of this is usually something caught in the blower housing,preventing motor from turning
Nov 12, 2009 | Whirlpool Dryers
My neptune dryer sounds like it is going to start but then fails
sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer hums when start switch is turned
you don't have to "pop" the top off the dryer. the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Aug 01, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore electric dryer when i turn it on all I hear is a humming noise
 hold down the door switch with tape and try to start it while turning the drum inside. if the motor doesn't start then you might need a new motor; expensive.
if the humming noise is actually the motor running and the tub is not turning then it is the belt; inexpensive.
Jun 28, 2008 | Dryers
Dryer problem
you need to either clean or replace the drive motor motors have two windings start and run windings both windings kick in on start up then the centrifugal switch kicks the start windings out and the run windings take over if nothing is jamming the tub go to the motor sme times getting the lint out of the switches and motor will fix it if not replace it
Jan 18, 2008 | Dryers
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
