Question about Magic Chef CTF2125 Top Freezer Refrigerator
Water collects in the vegetable bin left side only facing refrigerator
    Brigadier General:
  • 3,513 Answers
It may be that the drain line in the back that allows the water to drain from the self-defrosting freezer has become blocked. You can take the hose loose and **** it clean with a wet-dry vac .If you are careful, you might be able to break up the plug with a straightened-out coat hanger but you need to be careful to not poke a hole through the hose.
Also this type of problem can be caused by warm moist air being drawn into the refrigerator through a leak in the door seal. The air cools, and the moisture condenses into water and collects at the bottom.
Normally the interior of a refrigerator is lower in pressure and humidity than outside. That helps keep the door closed. If there is a leak in the door seal, then warm air can get in, and so can extra moisture.
Try inspecting your door seals, and clean both the rubber seals on the door, and the door jams that they rest against when the door is closed. That might be enough to prevent the leak.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water collecting and freezing behind vegetable drawer left side of GBSCOHCXFRWW
blocked drain.
pull the fridge out and look at the back. somewhere (unless it has cover panel) you should see a small hose. this is the drain tube. blow through this and you will most likely feel it clear out a bit. then open the fridge. good chance there could be a bit of a mess to clean up
May 18, 2014 | Refrigerators
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water is collecting on the left side on shelves and vegetable bin
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Whirlpool Refrigerators
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
defrost it, remove back panel on freezer side, and unclog small hole where water collects
Feb 13, 2010 | Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water runs under the vegetable bins
There should be a collecting channel with a hole and a tube reaching down to somewhere above the cooling compressor (Back of unit) where it should evaporate with the heat.
Most people never clean that hole and tube simply because they do not know what is for or the manual is silent. Sometime can be jammed with little icecube. I us thick plastic line from toy to clean, electrical wire with copper core not naked is also oke. Do not put wild force. This is the cooler part. The deep freezer part needs defrosting on temporarily basis and for that you need some small low bin to start collecting or keep on mobbing the floor.
Apr 14, 2009 | Magic Chef Refrigerators
Magic Chef CTF2125 Top Freezer Refrigerator Logo
71 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
