We have a schneider tv and a bt vision box we have used a grey remote from bt but we had to have a new remote as ours went faulty we have tried all the codes from bt but unable to programme the new one to switch the tv off and on maybe you can send another code or offer some advise many thanks m emsley
    Problem Solver:
  • 5 Answers
The remote control should have come with a leaflet/booklet containing a table of figures; these are the codes you need for your tv.
Failing this, check the leaflet/booklet for instructions on how to search for the code, using a key sequence on the remote; this is a long, drawn out process, but it may just work.
If all else fails, try using google to search for any web pages that may offer you the necessary code.
It might be worth the time involved to search the web for an answer.
Beyond that, contact the manufacturer of the remote control & ask them for the correct code.
In my experience, there are only a small number of tv manufacturers whose products are difficult to use with universal remote controls, but Schneider is an obscure make, & if it turns out to be not possible to link up the remote control, you may want to consider buying a new tv, but check that it will work with the remote control, before buying it.
Hope this has been of some help to you.
Thanks,
Steve.
Posted on Oct 01, 2010
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Codes for tuning bt vision box to sanyo tv
Here are the codes:
First try the 4 digit ones:
0136, 0242, 0722, 0732.
Now try 3 digit ones:
106 154 155 156 157
160 208 210 216 267
275 282 316 319 320
322 360 0236, 154,182 ,190, 191, 220, 221, 278, 282, 283, 323.
Goodluck..
Feb 14, 2008 | Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
I have a Bush 2878 TV and have just got BT vision box. The codes bt vision give do not work to control the remote - can you help?
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Oct 27, 2009 | Televison & Video
Bt vision remote
www.remotecodelist.com .....................................T.
Mar 20, 2008 | Televison & Video
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
