Question about Fahrenheat Built-In Baseboard Thermostat Heater
I need to find two replacement thermostats, part # F2546NWC for my fahrenheat baseboard heaters. Could you tell me where I can purchase them at? Thanks for your help
  • Fahrenheat Master
  • 2,519 Answers
Try national energy they do on line parts
Posted on Oct 02, 2010
We installed fahrenheat f2546nwc baseboard heat and when we turn it on it smells like something is burning, maybe plastic. we have a honeywell thermastat , not sure how to tell if its double pole or if...
Sounds like possibly you haven't removed all packing material. All machines will produce a strange odor upon start up but should go away rather quickly. Be sure to Read the manual in it's entirety
Aug 02, 2017 | Fahrenheat F2543 Baseboard Heater
What thermostat do I use for a model f2546nwc heater where the thermostat is mounted on the heater
u have to use a double pole thermostat...u can find it a homedepot...it has 4 wires- 2 red and 2 blacks..i just installed mine on 11/7/10...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
My three pole switch burned out on the baseboard heater. Need replacement switch. Thanks
Representative from Fahrenheat contacted me and is mailing me the part
needed. Thanks for the web site.
Dec 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Smell
the heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Dec 19, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Built-In Baseboard Thermostat Heater Logo
168 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
