Question about Panasonic Panafax UF-560 Plain Paper Laser Fax
On memory when i power off the fax machine the display will automatically blinking and whatever i programmed that is chahnged explain please
    Scholar:
  • 159 Answers
You need to change the battery. It is a Ni-cad rechargeable battery. The battery cover is located below the handset cradle. You may have to remove the cradle 1st, then the battery cover is removed with 1 screw.
Posted on May 27, 2008
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
Hi - it says on the display printing online but nothing is happening
Turn off the power, hold down the red clear/stop button while turning the power back on. This should reset whatever has locked up the printing memory.
Good Luck and Thank You for using Fixya.
May 27, 2010 | Brother FAX-8360P Plain Paper Laser
In Use/Memory green light blinking (and clicking)
There are three jacks on the left bottom side of the fax. Make sure the telephone line is plugged into the L jack not T or the telephone symbol.
Mar 13, 2009 | Canon LaserClass 2060P Plain Paper Fax
I'm trying to send a fax, but the machine is not allowing me to type in the recipient's fax no. The display panel reads "File storgae is full. Please wait".
Sounds like your memory is full. Either reset the power or try to take the memory off, there is a button on Panafax machines, then send the fax manually.
Aug 19, 2008 | Panasonic Office Equipment & Supplies
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
DISPLAYING FAX NUMBER ON OUTGOING FAXES
The machine will print out whatever fax number is programed into its memory not what line it is connected to.
Plug a standard phone into the socket that the fax uses and ring your mobile..
or if just dial your mobile from the fax (type in numbers press send) should see caller id on mobile
I think maybe your setup is a little more complex cause the T632 normally is just a laser printer but you must have the 3100 MFP Option.
manual link
http://www.lexmark.com/publications/pdfs/lexmark3100/eng/userref.pdf
Oct 18, 2007 | Lexmark T632 Laser Printer
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
62 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
