Question about GE Dryers
I have a DBSR463EG6WW dryer. When you turn the knob to start is just makes a huming noise and nothing runs.
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 01, 2010
Pushed start switch and making huming noise and won't start ge gas clothes dryer model dvlr223gg8ww
In most cases the motor is seized or something is preventing it from spinning (seized drum wheel for example).
Feb 10, 2015 | GE Dryers
I have a GE dbxr453ga2ww electric dryer, was working fine, but when I put a load in yesterday, I turned the start knob and nothing. No noise, no nothing! I would rather fix this rather than replace,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 06, 2011 | Dryers
Dryer will not turn on. Ive flipped the breaker and left it off for up to 5 minutes. Still no solution. THere is a humming sound coming from what sounds like the cycle knob. This is nothing new, it was...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 22, 2010 | Roper REX4634KQ Electric Dryer
Wont turn on
a huming motor is all ways bad news,,,,the motor has burnt out or is jamed so it cant turn,,,and that will burn it out as well!
most motors have two windings in there field coiles the start up winding and the run winding,,,if the start up winding has a fult in it it cant "kick start" the motor and if it cant "kick" it over the second run winding wont take over,,,so the motor stalls,,and it just humes??? but it gets very hot doing this!! causing a burn out!,,,,thats about the long and the short of it
boring huh? fitting a new motor should fix it,,,if its worth the price of a motor, plus fitting,,,
Jun 29, 2010 | GE DBXR463EBWW Electric Dryer
I turn the start knob and it just makes a buzzing sound
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
When I turn the cycle control knob it no longer makes a noise
heatman101
fg
May 30, 2010 | LG DLG7188 Gas Dryer
GE dryer makes loud huming sound wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Dryers
My kenmore dryer isnt working
if youm have a loud heavy huming noise and drum turns freely suspect motor bearings gone
Jul 31, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
230 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
