Question about Sony DSC-S930 Digital Camera
Flash is not working in my DSC-S930 steady shot camera. if i try to change flash settings. message appears on screen: Flash settings cannot be changed
SOURCE: sony cyber shot DSC-H3 flash
The same problem just appeared to us. We decided that it is a software bug and we reset the camera with the following combination:
Home ->Settings(the toolbox) -> Main Settings 1 -> Initialize.
This fixed the problem.
Have in mind that all your settings will be lost (but not the pictures).
Posted on Sep 19, 2008
jackboy
  • 2985 Answers
SOURCE: flash not working on Sony Cyber-shot dsc-p100
With the flash activated put the camera to you ear. assuming you have normal hearing when the flash capacitor is charging you should hear it.
If you cannot then assume the flash unit has failed.
Replacing it is possibly a no no
The economic cost make a new camera a better bet
Check out Sony to be sure
Posted on Feb 19, 2008
SOURCE: Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Posted on Dec 30, 2008
SOURCE: hi I have a sony cyber
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Posted on Feb 04, 2009
ripleymojica
  • 643 Answers
SOURCE: My Sony Cyber-shot DSC-W200 flash has stopped working and when I try to reset it it tells me that flash cannot be reset. What can I do?
its circuit error need to replace flach unit
Posted on Jun 01, 2009
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
HOW TO ADJUST FLASH SETTINGS
The Flash mode in the Camera can be changed by pressing the Right Arrow button (>) continuously which will change the settings from Flash Forced ON, Slow Synchro and Flash Forced OFF.
Flash Level can also be adjusted in the Camera by selecting the Flash Level option from the Shooting Menu of the Camera.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony DSC-S930 Digital Camera
I have a Sony Cyber-shot DSC-W90. When I try to change the flash settings, a notification pops up on the screen saying, "Flash settings cannot be changed." I tried setting it in each mode (including Auto)...
Go to Menu/ Home and initialize camera to reset it for factory default settings to fix flash light settings bug.
If problem still not solved, let me know do you see any error code flashing in top right corner of lcd?
Aug 24, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash won't work and flash setting cannot be changed from menu
This is eather caused by a bad flash circuit or a bad mainboad. Repair cost around 65.00 to 75.00 to repair.
May 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
easily just reset the camera with a pencil.
Aug 14, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony DSC-S930 Digital Camera Logo
275 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
