Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool Thin Twin washer won't start, just makes humming sound
I have a Whirlpool thin twin and after the washer fills with water it won't start the cycle but makes a humming sound. I thought I smelled rubber the day that it quit working. Any ideas? Thanks.
  • beefaroony Dec 20, 2008
    My washer has same problem but different brand it is a kenmore
  • 868 Answers
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
  • sweetdesires Oct 27, 2012
    i think it has a broken coupling ex put one in that rke before sons girlfriend puts 2 many clothes in at a time.need to fine out where coupling,and belt are located. someone will help me put parts in..just need no where they are to look at them,and try an get the parts.
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Whirlpool thin twin LT5000XUWO why water not shutt off overflows
bad water solenoid, underneath that is the unit that the water goes to and there are wires coming from it it is sticking in the on position
Aug 25, 2014 | Whirlpool Thin Twin Washer and Electric...
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Oct 28, 2012 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Machine fills with water, then hums.
sounds like the timer may be heating up!
Jan 01, 2010 | Whirlpool LSQ9610L Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
1,627 people viewed this question
Dan Webster
Dan Webster
Sal De
